new ALCS external footage counter for Aaton cameras
Aapo Lettinen
I am working on a simple external footage counter which works with Aatons (at least LTR, XTR, Prod, 35-3 ) which is relatively affordable.
will have at least footage counter ( ft/m switchable, switchable to count up or down) and battery voltage meter. Will likely have some other features as well depending on how much budget I can secure. I have possibility to add simple crystal speed generator for example if there is need for it.
preorder-only item and relatively tight schedule, let me know in the following weeks if interested. I will need to know the approximate batch size early on to be able to lock down the design and order the parts before Christmas rush 🙂
Link to comment
First draft of the front panel. A small Oled display and three control buttons. planned size of the device is about 56mm x 61mm x 30mm or so, same sized than my 50-speed Aaton crystal controller and small and lightweight enough to mount with velcro if needed 🙂
Link to comment
Some size reference photos with the cardboard front panel draft. As you can see it is really compact device 🙂
the items in first image for scale, the card is standard credit card size. The camera is LTR7
Link to comment
Will have basic crystal speed generator included, probably about 10 crystal speeds with most used ones like 23.976, 24.00, 25.00, 29.98 and 33.333 fps included 🙂
Link to comment
