I've decided to sell all my remaining ACL components and parts. The S16 body is not quite ready to sell, but we begin...Any offers please direct message me or email me   viz(at)xtra.com.nz  or phone me with WhatsApp..  64 274 377 086   (08:00 to 22:00 NZT)
There are links to more pics at dropbox under each heading. Any problems with access let me know. I may edit this later if any errors or improvements needed.
I also listed this on the Cinemarketplace forum  ..https://cinematography.com/index.php?/forums/topic/103570-eclair-acl-components-and-parts/
1) ACL II S16 BODY, no motor or eyepiece
pics at dropbox.. https://www.dropbox.com/scl/fo/fs7ao30o45ffyd9preapg/AEJhWgq9P1hq6-PZjIJan1U?rlkey=a5tusjicswi72qi6bp7aeru99&st=w8sxyd47&dl=0
The item is with a technician at Panavision getting a new 9 pin Canon motor connector. It may be with him for a month 'till he has time after hours, so there is time to consider how best to sell it and take questions.....
 My spare ACL II body, no motor, eyepiece or handle module. S16 conversion by Visual Products. VP conversions are about the best, with really nice, simple ground glass markings. The ACL II base, I don't know if it was a bespoke factory original or someone's aftermarket piece. The machining, apart from the front shape, looks the same as factory standard, including the labeling. The rod mount is almost integral at the front.... looks really useful..no plate needed.
Needs a CLA and a couple of hopefully small repairs...
I've never used it, but ran scratch tests to assess it (scratch free). Sounded like the shutter was just lightly ticking against the body. Also, one of the motor mount threads on the body is striped, so probably needs a thread insert. I emailed Paul at Visual Products and it sounded like the shutter ticking noise might get fixed within a CLA. It may be something easy like the mirror connecting rod.  If it's difficult then maybe a couple extra hours.
There could be a couple of options on how to sell this....I could sell as is. When the connector is replaced we could assess the noise. Or, I could send it to Paul at VP for CLA, repair then set a price
A thought re the stripped motor mount screw.... That one screw has only a very thin section of body casting to anchor to. The other 3 screws are threaded into much stiffer sections, so I wonder if 3 screws are probably enough. I can ask Paul later.
Added notes...
If there is a new 9 pin Canon connector in one of the photos please ignore it. It's not included.
The 9 pin Canon connector at the side grip location..has a big chip out of the plastic surround. The metal p
ins are all good and the connector works just fine.
EDIT: For the latest prices scroll down to last post.
2) ACL multispeed motor
pics at dropbox https://www.dropbox.com/scl/fo/ef8hntmi8lswndudmlwjo/AKYnbwbJWNZXU0aLn9Ezps4?rlkey=2uofa0lgo7xo7fy7ni2bbhdjw&st=9yvsy87o&dl=0
Heavy duty, late model Thomson crystal sync motor (MIMUL) with crystal speeds of  8fps, 12fps, 24fps, 25fps, 50fps, 75fps.   Mirror parking on camera stop (meaning the mirror always stops in the viewing position).  Serviced by Andrzej (AZ Spectrum) in July 2023 and  not used since. Cosmetic condition quite good. A couple scratches and paint chips that the techs touch up.
AZ Spectrum invoice in the photos.
PRICE.   $1300
3) FRENCH ACL MAGS
dropbox pics at https://www.dropbox.com/scl/fo/peubt0fb83952tjzbict6/AMVW4xSgubP7MAUtm5BrUG8?rlkey=ogxfip3ppmrtm1nngh593b7uq&st=ruyb70g9&dl=0
All mags are late model French with the separate little pressure plate over the gate. Like an SR, the film is held in a precise gap by the long pressure plate, and only the little plate over the gate applies pressure.
- 400' French ACL mag, S16, machining looks nice. Fairly tidy looking. Needs CLA, but really just lubrication. ("Pat 1"),  #SD-503, with cap. PRICE USD800
- 400' French ACL mag, standard 16. Fairly tidy looking. Needs CLA, but really just lubrication. ("FR3"),  #SC-797, no cap.   PRICE USD650 (you can buy a 3D printed cap on eBay for USD55)  EDIT: SOLD.
- 200' French magazine,standard 16, in as new condition, friction feels low, but should have lubrication soon, #D98, with cap.  PRICE USD800....EDIT: SOLD
4) ACL MAG PARTS SELL        EDIT: On eBay this mag has been parted out into several items.
dropbox at https://www.dropbox.com/scl/fo/ahux7jypyku5ls9u7f449/ABc2z_xeJVOUdHABIouUYtw?rlkey=y0r1oxtpnatyz6dz274w6hq4l&st=mf9hn5z0&dl=0
400' English mag for parts.
Has a French throat, otherwise is all English. Missing feed side door, platters.
Belts, spindles, rollers, guide shoe assembly all good. Drive sprocket, I cant remember what the ball bearing was like.
Partly disassembled, I could probably disassemble completely and just ship the bits and pieces, leaving the body and door behind.
USD100 as is......
USD120 just the bits and pieces, no body/doors....
Support plate assy with guide shoes and rollers, complete less sprocket assembly (MIN 445 E/A)...New
Later model French. No mounting screws. One of the recommended mods if running high speed. See the Eclair ACL Parts Catalogue (not the UK one), page4, shows pics of the different plates.
Drive sprocket spindle assembly for French mag (315 E..?)....used
Ball bearing and shaft feel ok but shaft has a little bur right near the tip that needs smoothing before reassembly. The "pulley" on the assembly body that drives the take up belt has some little dents and burs that will need to be smoothed out (mostly just careful straightening.
PRICE USD120 for support plate assembly and sprocket assemblies together.....
French 400' mag doors...New.
Brand new alloy doors, L/R. No latch hardware. There is one white disck for the big latch knob. (MIN 717, 727)
Sound deadening for French 400' take up door...New  (MIN 707/708)
It has laminated layers. There is a lead impregnated layer.
The factory screwed up when they laminated the rear part of the sound deadening, with the layers in reverse order. To use it, one would have to delaminate it and glue it back in correct order. The outer surface of the black vinyl stuff may then have old glue to clean off. Maybe one could use new vinyl for that part.
USD160 for doors and sound deadening together...Shipping
French 400' footage counter face plate. New. (MIN 748, 749, .. ?)
Has 3 layers:  printed metal face plate/ clear plastic/ inner metal face plate.
PRICE USD150 for doors, sound deadening and footage counter face plate together...Shipping
20250630_142849.thumb.jpg.bd7ae848c77120a7fa6fb7cfde489577.jpg20250630_143524.thumb.jpg.9574307b7bf9a63af67229f3516bf55c.jpg
5) Arri S adapter for Eclair ACL   EDIT: SOLD
dropbox pics at https://www.dropbox.com/scl/fo/z02yjls363fa5kqavubia/AMgsr3uilOWRww8QTE-G0iQ?rlkey=zuljlulh4so0vwmjv3cmchrn6&st=wxzcuqjh&dl=0
TS/Arri-S (standard) adapter for Eclair ACL.   This mount will let you use older Arri,  Zeiss,  Schneider lenses,  also old Cooke Kinetal.  The Kinetal will turn OK in the lens port if it is loosened a tiny bit (normally have a light smear of lubricant).   This is the standard Arri S adapter that was sold with the ACL cameras.  Good condition, all thread movements smooth,  some signs of use,  some wear on the anodized coating on the front flange,  but nothing that should affect FFD.  Rear flange good.   Just what's in the photo,  no front or rear cap.  There are proper caps for an Arri S port that you could buy somewhere,  or scrounge up used ones.  Being a Kiwi I have used a plastic cap off a vegemite jar.  I can maybe find a spare one to go with.
PRICE.   $450
Edited by Gregg MacPherson
more words
  • 4 weeks later...
Those are all on eBay now (except the camera body, not yet listed). Search Eclair ACL in Camera and Photo category..Prices may come down if they sit. For sale outside eBay assume price reduces by 13%...
  • 2 weeks later...
EDIT.....
Update on my ACL components/parts.....see photos above..
What remains is listed below...I've ended all my eBay auctions for now. Shipping was problematic. I can't sell to anyone in the USA untill shipping from NZ resumes. Tariff problems.
The S16 ACL II body will hopefully have its canon connector replaced very soon. Then I can set a price.
Eclair ACL motor (MIPLE, heavy duty) just serviced..............$1,100.00
Sorry for incorrectly calling it MIMUL previously.
400' French Eclair ACL mag, S16 ............................................$550.00
Eclair ACL mag doors, sound proofing, counter face, new.....$40.00
I may still have some parts for the 400' English Eclair ACL mag. The sale of some parts is pending, so enquire later.
update
  • 4 months later...
Hey Gregg,
I ended up winning the auction for the 2 ACL mags (200’ and 400’ English mags). I would love to discuss what replacement parts you have available for them. Cheers!
