Nguyen MInh Phuc Posted January 5 Posted January 5 https://youtu.be/Q1QW0kd4yuI Hi everyone, I recently watched Ky Nam Inn (Quán Kỳ Nam) in the cinema. The film was shot by DOP Bob Nguyen, A.C.S. After the screening, I attended a workshop where the crew shared their workflow and behind the scenes process, which made me curious about some of their creative choices. Bob mentioned that the film was shot on Kodak Vision3 500T, rated at El 400, then process the negative at iso 2000. He explained that this combination of overexposure at capture and push processing during development was an intentional aesthetic decision to achieve a specific look, increased contrast, richer color, and more pronounced grain. I'm still trying to fully understand the technical mechanics behind how overexposure combined with push processing leads to these visual characteristics. Could someone explain how this works? Additionally, are there any books or resources you would recommend for learning more? And are there other films or cinematographers known for intentionally rating film stock off its box speed or using push/pull development as part of their visual language? Thanks so much! 1
Gautam Valluri Posted January 5 Posted January 5 (edited) The trailer looks beautiful! Exposing 500T at 400 ASA is a 1/3 stop overexposure. This a lot of DPs do in any case as it gives you a cleaner image by exposing the smallest grains. Then developing it as if its 2000 ASA is a 2 stop push, which the 500T handles nicely and increases contrast and slightly crushes shadow details to give you denser blacks. If followed with a decent 4K scan, you can achieve some beautiful images as we see in the trailer. Keep in mind that this film was shot on 35mm, where pushing 2 stops will still give you a pretty clean image. I'd like to see something like this done on 16mm and see what happens. The grain should be more apparent. In any case, thanks for the discovery of this film. I hope I'll get to catch it in the cinemas. PS: Did the DP mention if there was a Digital Intermediate for this film? Edited January 5 by Gautam Valluri Question about digital intermediate
Gautam Valluri Posted January 5 Posted January 5 8 hours ago, Nguyen MInh Phuc said: And are there other films or cinematographers known for intentionally rating film stock off its box speed or using push/pull development as part of their visual language? Stanley Kubrick did this on Eyes Wide Shut. There are many threads in the forum where this was discussed at length. It'll be good reading. You will also find some tests here where 500T was pushed 2 stops and shot in ambient light outdoors in an urban environment.
Premium Member David Mullen ASC Posted January 5 Premium Member Posted January 5 Rating 500 ASA film at 400 ASA is hardly overexposure, it's within a margin of error for exposing in general. You do it more as a safety net, that your exposure leans from normal to slightly over as opposed to normal to slightly under. Plus push-processing is not exact in terms of the extra density it gives you, so pushing 500 ASA film by two-stops to 2000 ASA but setting your meter to 1600 ASA is again just playing it safe. You're not necessarily ending up with a +1/3-stop extra density. Another film that did this besides "Eyes Wide Shut" was "Red Dragon", shot by Dante Spinotti. 1
Nguyen MInh Phuc Posted January 5 Author Posted January 5 3 hours ago, Gautam Valluri said: Then developing it as if its 2000 ASA is a 2 stop push, which the 500T handles nicely and increases contrast and slightly crushes shadow details to give you denser blacks. If followed with a decent 4K scan, you can achieve some beautiful images as we see in the trailer. On a technical level, how does push processing increase contrast and compress shadow detail?
Nguyen MInh Phuc Posted January 5 Author Posted January 5 1 hour ago, David Mullen ASC said: Plus push-processing is not exact in terms of the extra density it gives you, so pushing 500 ASA film by two-stops to 2000 ASA but setting your meter to 1600 ASA is again just playing it safe. You're not necessarily ending up with a +1/3-stop extra density. The DP rated Vision3 500T at EI 400, then pushed the film two stops in development to get more contrast, richer color and denser blacks. I get why he rated it at 400 as a safety measure, but why does pushing two stops actually produce those visual changes?
Premium Member David Mullen ASC Posted January 5 Premium Member Posted January 5 I misunderstood the original question because of the mention of "Eyes Wide Shut" -- in that case, the 500T film was rated at 1600 ASA -- instead of 2000 ASA -- for the 2-stop push. So the 500T was initially rated at 400 ASA as a base for the stock itself but underexposed 2-stops from 400 ASA (i.e. rated at 1600 ASA) and then pushed 2-stops. Maybe that's what the DP of "Quán Kỳ Nam" meant as well, otherwise if he really overexposed by 1/3-stop and then on top of that, pushed by 2-stops, then in theory his negative ended up with a 2 1/3-stop excess density. I think "Babylon" did something less extreme but similar, I think the DP pushed one-stop but did not underexpose, ending up with an extra stop of density. I might be misremembering that -- maybe he overexposed by one-stop and then pushed by one-stop, ending up with 2-stops of extra density. Pushing gives you an increase in contrast and grain but if you don't underexpose at all, you'd mostly be getting the increase in contrast.
Karim D. Ghantous Posted January 6 Posted January 6 11 hours ago, Nguyen MInh Phuc said: On a technical level, how does push processing increase contrast and compress shadow detail? I remember this from a book about film processing: exposure determines shadows, and processing determines highlights. So, an underexposed negative that is push processed will therefore have dark shadows and bright highlights. The opposite happens with overexposure and pull processing. I don't properly understand the chemistry, however.
Gautam Valluri Posted January 6 Posted January 6 On 1/5/2026 at 2:30 PM, Nguyen MInh Phuc said: On a technical level, how does push processing increase contrast and compress shadow detail? The way I understand it is when you "push process" a negative, it stays longer in the developer and therefore the silver halide crystals in each of the blue, green and red-sensitive colour layers of the negative get "more developed". More time in the developer = more colour saturation and deeper contrast but only until a certain limit as its a curve that descends with diminishing returns after what I assume is 3+ stops. The reason it crushes shadow detail is perhaps because the blacks emerge when each of these colour layers take on their corresponding dyes (Cyan, Magenta and Yellow), like a mix of C+M+Y values that if either one or more of them are too much just give you deep blacks with very little detail in it. This is why in printing and graphic design, there is a K, a black value on top of the CMY values. Pure black in offset printing would be C0, M0, Y0, K100 but to get a deeper, richer black one uses C50, M50, Y50, K100 or some other combination as long as it doesn't surpass 300 overall value. I hope I'm not confusing things further. Someone please correct me if I'm wrong.
