A while ago here some university student did some really interesting tests comparing 35mm stocks to 16mm, and concluded that 50D in 16mm is comparable to 500T in 35mm.
I cannot for the life of me find that post again. Does anyone remember it and can link me to it please?
You mean in daylight with ND on the 500T? What are the equivalents? I am bit perplexed and piqued at the same time.
That is why I want to revisit this test done by some young student and it was posted here about a year ago or so? I forgot the details and I forgot to bookmark it.
The sample must have been horrible quality. I've shot quite a bit of 5219, 4 perf, 3 perf, 2 perf, it's WAY sharper than 50D on 16mm. Even in 2 perf, you're still dealing with a 2mm shorter negative on 16mm. Plus with 35mm for the most part, you're dealing with pin registered cameras with a lot more control over the flange distance and registration. To get the sharpest image out of 16mm, you also kinda need a SR3 or 416 with Ultra Primes. You'll also need a high res scan, something that over samples quite a bit actually. Where it's true 50D on 16mm can be pretty good, it's also very noticeably 16mm especially when using shorter lenses.
