Paulo Arellano Posted September 5 Posted September 5 Hey guys I need to build a new Arri 2C battery and seeking help on it. I had been using this battery which can be found here however if the battery isn't charged for a few months the whole thing would die. Does anyone here have any other suggestions ?
Mark Dunn Posted September 22 Posted September 22 Well NiMhs should hold charge for a few months- are you sure you're charging them correctly? I believe NiMhs are suitable for the 2C, so maybe you've just worn it out.
Fabian Schreyer Posted September 22 Posted September 22 What motor are you using? I use a cheap power tools battery pack together with an Aliexpress adapter for my IIA.
Paulo Arellano Posted September 22 Author Posted September 22 1 hour ago, Fabian Schreyer said: What motor are you using? I use a cheap power tools battery pack together with an Aliexpress adapter for my IIA. The constant speed motor. Nothing over 24fps.
