Filip Plesha Posted February 9, 2005 Share Posted February 9, 2005 can someone explain to me in a few words, how do those single-axel magazines work. Where does the film go when it's exposed? Is it side by side with unexposed film on the same axel? (that would make the magazine quite wide) Link to comment Share on other sites More sharing options...
Filip Plesha Posted February 9, 2005 Author Share Posted February 9, 2005 So, nobody has time to spare or I don't deserve an answer to such a stupid question? ;) Link to comment Share on other sites More sharing options...
Rik Andino Posted February 9, 2005 Share Posted February 9, 2005 Do you mean coaxial magazines? They're a simple concept. The magazine has two sides put side by side The simplest way to explain it is--->sorta like an Oreo (two cookies side by side) It's quite hard to explain without pictures but... A coaxial magazine has both sides (the take up and the feed) stuck together The feed compartment is on one side of the mag (right for Aaton, left for Arri SR) And the Take-up compartment is on the other side of the mag. Depending on the concept you either pass the film through the pressure plate Which is ingeniusly already attached to the magazine And then thread on the take-up side or you (Like the Arri SR) Or push the film through to the take up side then pass it through the pressure plate And then thread it again as it comes back in to the feed compartment (Like on the Eclair or Aaton). It's a quite simple concept Coaxial magazines are easier to load than Mitchell mags or Displacement mags And can make the camera shorter (but longer) The Aaton LTR/XTR and the Arri SR1/2/3 both have coaxial mags Check out these manuals http://www.cinematography.com/forum2004/in...?showtopic=2750 http://www.cinematography.com/forum2004/in...?showtopic=3694 http://www.cinematography.com/forum2004/in...?showtopic=2746 http://www.cinematography.com/forum2004/in...?showtopic=2747 I would also recommend you check out the ACS manual They have lots of good illustrations there And Perhaps also The Professional Cameraman's Handbook. The best way to understand a coaxial magazine is to see if in person Perhaps you can go to your local rental house or Film school Or meet someone who has a camera with a coaxial mag Such 16mm cameras like ECLAIR, AATON, and ARRI SR all have coaxial mags So does the Aaton 35, the Arri 35BL1/2/3/4, and the Arri 535 Anyways good luck and I hope you were able to understand my answers Link to comment Share on other sites More sharing options...
Filip Plesha Posted February 9, 2005 Author Share Posted February 9, 2005 Yes, I get what you mean, I've suspected something like that thank you Link to comment Share on other sites More sharing options...
Mike Panczenko Posted February 9, 2005 Share Posted February 9, 2005 The 535 and 35BLs do, but the Aaton 35 is displacement. Link to comment Share on other sites More sharing options...
Rik Andino Posted February 9, 2005 Share Posted February 9, 2005 The 535 and 35BLs do, but the Aaton 35 is displacement. <{POST_SNAPBACK}> It's a displacement magazine? Even the Aaton 35-III? I've don't work with 35mm usually, and don't AC much Only worked with the 35BL and the 2C So I don't really know about the Aaton 35. But since it looked so much like the XTR I thought it had the same magazines Gosh it looks too small to be a displacement magazine. Well thanks for enlightening me. Link to comment Share on other sites More sharing options...
Premium Member Michael Nash Posted February 10, 2005 Premium Member Share Posted February 10, 2005 It's a displacement magazine? Even the Aaton 35-III? Gosh it looks too small to be a displacement magazine. <{POST_SNAPBACK}> That's kinda the point behind having a displacement mag! ;) It only has to be marginally bigger than one roll of film, since the takeup roll "displaces" or fills the void left in the exposed part of the feed roll. Operating the Aaton 35 is a lot like shooting Betacam in terms of size and weight. Link to comment Share on other sites More sharing options...
Rik Andino Posted February 10, 2005 Share Posted February 10, 2005 It only has to be marginally bigger than one roll of film, since the takeup roll "displaces" or fills the void left in the exposed part of the feed roll. <{POST_SNAPBACK}> But isn't that also the same principle in a coaxial magazine? I looked at the Aaton 35 manual and the mag is a displacement It's one of the strangest displacement mags I've seen though Do they make 1000' versions? It would make the camera very heavy... Why didn't Aaton decide on a coaxial mag like they did for the XTR? Link to comment Share on other sites More sharing options...
Guest Sean McVeigh Posted February 10, 2005 Share Posted February 10, 2005 But isn't that also the same principle in a coaxial magazine? <{POST_SNAPBACK}> A coaxial magazine places the reels side-by-side coaxially as the name implies (both spin around a common center point). A displacement magazine is very similar to a traditional 'mouse ears' style magazine, except that the spools are not stationary. Here's a quick diagram... pardon my poor ascii art. A ((((1)))) B (2) C A,B,C are empty spaces in the magazine. Imagine a set-up in which spaces A,B,C are kept to a minimum throughout the entire run. As film unspools from core 1 onto core 2, space A becomes larger, while space C becomes smaller. (assume space B stays relatively constant for argument's sake). This is how a typical magazine works. In a displacement magazine, as the film spools off of core 1 and onto core 2, the entire assembly shifts from right-to-left, meaning that spaces A and C neither grow nor shrink. The net result is that no space is wasted in the magazine and it can be kept sufficiently smaller than a traditional magazine. In a coaxial magazine, it's an entirely different beast. It's basically a traditional magazine, but folded in half, making it roughly half as tall and deep, but twice as wide. No real net savings in space (volume occupied). A displacement magazine can in theory be about 33% smaller than a traditional magazine. Hope that makes sense. Link to comment Share on other sites More sharing options...
