Dana Dolly
Travis Gray
My only issue was the speed of the wheels - they had not much resistance. I'd rather have to put a bit of weight behind my moves. Without any resistance, gradual movements weren't as easy as I'd like. I suspect there's a common piece of kit I don't know about that would be an addition to the Dana?
I usually have one hand on the Dana to push, so I let my fingers drag on the wheels to provide a little dampening on moves. I use it with an O'Connor 2575 head and a large camera, so it has more inertia to begin with.
Link to comment
Cheers, sir.
Yeah, such techniques may do the trick but a heavier push is still much better
Link to comment
You could add a shot bag to increase momentum and make the moves smoother, but too much weight on speedrail would be undesirable. You could switch the wheels out to ones that are softer and a stickier composition, but the simple construction doesn't allow the addition of a device to add a variable about of drag to it. It is what is, a roller skate.
Link to comment
