Adam McDaid Posted January 10, 2016 Share Posted January 10, 2016 FlowCine Gravity One & Alexa Adaption Plate / $4000 OBO Gravity One: The G-1 is the perfect companion to your Easyrig. It helps with common problems such as the string “fight back force” and also helps stabilizing your shots when moving. It also helps correcting for rotation jitter in both the roll and tilt axis. Alexa Adaption Plate: The adaption plate is a super slim top cheese plate that will enable you to put the balancing stage anywhere on top of your Arri Alexa/XT. The Slide In option, will let you easily slide on and off the Arri top handle or the Gravity One. If interested, contact me at adammcdaid@gmail.com. Link to comment Share on other sites More sharing options...
