tim ara Posted January 8, 2018 Share Posted January 8, 2018 For Sale - USED TV LOGIC 5.6 HD Monitor VFM-056WPI have a Few to choose fromAll have been professionally maintained and calibrated by TV LOGIC in BurbankThey all are calibrated and cleaned before saleThese are the WP models which have the "advanced" feature of HDMI to SDI conversion - use to be $300 extra just for that upgradeAll include the original shield and AC power supply / right angle BNC / top and Bottom mounting hardware - everything included like original brand new unit - minus the boxCome test it, bring a camera if you'd likeMonitor only - $525.00Monitor and P-Tap cable - $565.00contact direct for fast easy communication: TIM@CINOFLEX.COM or SALES@CINOFLEX.COMTV LOGIC - VFM-056WP : 5.6” Light Weight Compact ViewfinderThe VFM-056WP is available in two configurations and is ideal for HD-SLR production. A 6"x 4"x 1" lightweight magnesium-alloy case houses a 5.6” 1280x800 LED backlit LCD display with a full complement of preferred features, including DSLR Scale, Focus Assist, Various Scan Models, Markers, Audio Level Metering with speaker, Time code Display, HDMI loop out via HD-SDI(720p), WaveformVector Scope, Y Level Check and Range Error Check.Display Spec.Size 5.6"Resolution 1280 X 800 (16 : 10)Pixe Pitch 0.094mmColor Depth 16.7MViewing Angle 170°(H) / 170°(V)Luminance 300cd/m2Contrast Ratio 500:1Display Area 121(H) × 76(V) mmInput1 X RCA Analog Input (Composite)3 X RCA Analog Input (Component)1 X BNC 3G-SDI A Channel Input1 X HDMI HDMI InputOutput1 X BNC 3G-SDI OutputAudioAudio Out Analog Stereo (Phone Jack), Internal Speaker(Mono)FPGA Functions, 3G-SDI Level A/B, Audio Level Meter Display, Blue Only, Focus Assist, H/V Delay, Luma(Y') Zone Check, Marker, Max Brightness On/Off, Mono, Range Error, Temperature Adaptive Color, Time Code Display, User Aspect, Various Scan Modes, Waveform/Vector, ZoomClosed CaptionCalibrationOther FunctionsUSB Firmware update by USB cableEthernetConversion HDMI-to-SDI, SDI-to-SDI, Link to comment Share on other sites More sharing options...
