Gerald Martindill Posted December 27, 2019 Share Posted December 27, 2019 Hello hive mind, im shooting in a large corner set, With 3 Arri650 fresnels. When shooting wide shots, I always get shadows from the set pieces close to the walls. can someone explain to me how to get rid of them? the Arris are set up in a 3 point triangle formation about 5/6ft high pointing slightly downwards. Do I need a fill light/panel light Directly above the walls pointing at them? or what should I do? im usually working in art dept, so please excuse my green question. thanks, g Quote Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted December 28, 2019 Premium Member Share Posted December 28, 2019 The classic or old-fashioned way of hard-lighting sets was to try and separate the walls from the actors in the center of the set. This required a lot of barn doors and flags, and it helped that the lighting was coming from a high angle above the set. Since the foreground lighting was mostly flagged off of the walls, the walls and furniture along it would get their own spots, accent lights -- a snooted spot on a painting or the center of a blank wall, or barndoors closed down to create a square-ish lit area on a wall, or a down spot on a cabinet, etc. Since it sounds like you don't have that many lights, my suggestion is to light in a more modern soft light style, maybe a top soft light in the center skirted on the sides to create a cut along the top of the walls. At least try Chimeras with egg crates on the three ARRI's to soften them. The lighting should be emulating a practical source like an overhead dome light or chandelier, etc. 2 1 Quote Link to comment Share on other sites More sharing options...
Giovanni D'Onofrio Posted December 29, 2019 Share Posted December 29, 2019 (edited) On 12/28/2019 at 2:35 AM, David Mullen ASC said: The classic or old-fashioned way of hard-lighting sets was to try and separate the walls from the actors in the center of the set. This required a lot of barn doors and flags, and it helped that the lighting was coming from a high angle above the set. Since the foreground lighting was mostly flagged off of the walls, the walls and furniture along it would get their own spots, accent lights -- a snooted spot on a painting or the center of a blank wall, or barndoors closed down to create a square-ish lit area on a wall, or a down spot on a cabinet, etc. Since it sounds like you don't have that many lights, my suggestion is to light in a more modern soft light style, maybe a top soft light in the center skirted on the sides to create a cut along the top of the walls. At least try Chimeras with egg crates on the three ARRI's to soften them. The lighting should be emulating a practical source like an overhead dome light or chandelier, etc. Thanks for the good explanation, doesn't get any clearer than this! Edited December 29, 2019 by Giovanni D'Onofrio Quote Link to comment Share on other sites More sharing options...
