Workflow: External recorder (ProResHQ) + proxy (ProRes) for Canon C200
Hello everybody,
I am trying  to wrap my mind around the idea of recording the material (in ProRes HQ) and proxies (also ProRes) simultaneously.
Does it make any sense?
The shoot itself is a series of lectures and promises a lot of data. Most likely I'll be using 2+ Canon C200 cameras.
So far I've been thinking about the following:
CAM - SDI - EXT.REC (SSD, ProResHQ) - SDI - DIR. MONITOR [no proxies]
CAM - SDI - EXT.REC (SSD, ProResHQ) - AJA Ki Pro Mini [proxies] - SDI - DIR.MONITOR
CAM - SDI - Atomos shogun 7 [no proxies]
CAM - SDI - ODYSSEY 7Q (material and proxies on separate SSDs) - SDI - DIR.MONITOR
Any experiences or suggestions shared would be much appreciated.
Most likely there is a simple and direct solution which might never occur to me otherwise.
Thank you,
Anz
Edited by Anzer Sizov
A few typos
Link to comment
Hello Satsuki,
I think the option you offer is a very good one, thank you. I was just wondering if there is any way to record some light-weight proxies in ProRes, too - something that escapes my mind. So that no additional transcoding would be needed. I've come across Shogun 7, which could be an option with its multiple input recording. Anyway, thank you for your contribution, Satsuki.
Anzer
Link to comment
  • Sustaining Member
I suppose if you could use a multi-input recorder like the 7Q to record all of the proxies to a single device/SSD, then that would help cut down on the number of devices to manage. I wasn’t aware that the Shogun 7 could also do that, but that would be useful.
Link to comment
Well, I hope both of these devices do exactly what the tech. spec. says they do.
I have not yet tried it myself, but this separate multi-recording feature might be a very convenient tool.
Thank you for your support, Satsuki!
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Forum Sponsors
FJS International
Film Gears
DMX-iT
Cinematography Books and Gear
