Eric Quao Posted April 23, 2021 Share Posted April 23, 2021 Hello, my name is Eric Quao. I’m a camera operator in the Philadelphia area. I have a couple of questions in regards to the Cooke Varatol 20-100 lens. If someone that is part of this database could reach out to me I would greatly appreciate it. Thanks Link to comment Share on other sites More sharing options...
Premium Member Dom Jaeger Posted April 23, 2021 Premium Member Share Posted April 23, 2021 Hi Eric, I work as a lens technician for Panavision, and have some experience with the Cooke 20-100. What are your questions? 1 1 Link to comment Share on other sites More sharing options...
Eric Quao Posted April 26, 2021 Author Share Posted April 26, 2021 1. The zoom ring has a high/stress point at the 25mm marking. 2. The T-stop ring has some stress/high points between the 4 and 16 stops. my assumption is that it just the ring needs to be cleaned out from the dirt build up over time. However, both rings function well. I just noticed those 2 issues. Link to comment Share on other sites More sharing options...
Premium Member Dom Jaeger Posted April 27, 2021 Premium Member Share Posted April 27, 2021 Most likely the rings just need a clean and re-lube as you surmise but it could of course also be an issue with the mechanics further in. Impossible to diagnose without inspection. If this is a lens you have recently acquired and you want to use it for work that matters to you then I would recommend getting a lens tech to check it. Link to comment Share on other sites More sharing options...
