Lewis Hart Posted August 13, 2021 Share Posted August 13, 2021 Hi all, hope everyones well new to Arri 16mm, interested to pick up a 16S tomorrow, the chap hasn't used it in some time has struggled to find a battery solution for it, he used some bike batteries for it he said, which I believe to be 6v, hence why it Never ran properly, (not sure he's super knowledgable etc) he has shot film and developed it, showed me etc, so it works. Has anyone found a good solution for a 8v source, ideally belt clipped, I know some have used a 12v power pack, with a resistor to bring it down to around 8v. Some posts I've seen some have used Bosch / various power tool batteries with a custom XLR setup, I guess these had resistors / potentiometers as they are usually 14+ v. I was hoping to use a V mount battery clip solution, as those are 14.v and you can step down im sure with a P to 8v? just guessing here. second question: I know the torque motor as far as im aware needs 6-8v, and the camera 8v, with both obviously needing a certain amperage to run properly. Could anyone give any ideas or what they've used that's worked with running the camera both from the 100ft rolls inside and if possible a solution for the 400ft mag up top - a battery solution and what amperage / voltage you need to power up both properly. I believe the camera has the wild motor with the R-F on it, Is this the one that goes from 4-40fps? thanks ahead for any help lewis Link to comment Share on other sites More sharing options...
Aaron Martin @ OH Posted August 13, 2021 Share Posted August 13, 2021 You might consider having your camera converted to a 12v, 4-pin XLR power plug. That's what I did, and I am able to use a belt clipped battery like this one: https://www.bhphotovideo.com/c/product/1048193-REG/bescor_fp_12vatm_12v_lithium_ion_battery.html This is what I use to power my camera for 100-foot loads. Wooden Camera also sells a V mount battery plate and a D tap to 4-pin XLR cable. https://woodencamera.com/products/d-tap-to-4pin-xlr-female-straight-20?variant=13109053784137¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=EAIaIQobChMI2f7osPGu8gIVlrWzCh12iwUUEAQYAyABEgK2hPD_BwE Link to comment Share on other sites More sharing options...
Roy Cross Posted September 5, 2021 Share Posted September 5, 2021 Hello Aaron, Can I ask who did your conversion and at what price? Thanks! Roy Link to comment Share on other sites More sharing options...
Aaron Martin @ OH Posted September 5, 2021 Share Posted September 5, 2021 50 minutes ago, Roy Cross said: Can I ask who did your conversion and at what price? Roy, It was Visual Products in Wellington, Ohio. I recommend contacting them for pricing and turnaround time. Aaron Link to comment Share on other sites More sharing options...
Roy Cross Posted September 6, 2021 Share Posted September 6, 2021 Super. Thanks! Link to comment Share on other sites More sharing options...
