Greetings everyone,
I was talking to a retired camera operator the other day and he mentioned that some of the viewfinders on the Eclair ACL are in fact now radioactive due to thorium decay.
He warned that while this is sometimes seen in older lenses it really isn't an issue because the radiation is low and blocked by the camera body.
But he said it is a very grave issue for viewfinders because there isn't anything to block the particles and because of this it can cause eye damage or worse.
Can someone elaborate on this somewhat?
Does anyone know if it's the Angenieux or Kinoptik viewfinder.... or possibly both?
Thanks!
-Eric
16 minutes ago, Eric Niemi said:
Greetings everyone,
Thanks!
-Eric
I don't know how anyone could elaborate on that unless them having a ton of various eclair acl viewfinders and a geiger counter with a pancake detector.
We just talked about this exact same topic on this forum just a while ago. The main conclusion was that everyone on this forum is radioactive by nature and you can's shoot with the camera without using the viewfinder so there is nothing you can do about it whether something being slightly radioactive or not ?
Thanks, Aapo for the response ?
Yes. I saw the Arriflex thread and I mentioned that to the camera operator and he said he heard some lenses in the viewfinder optical system were radioactive on some of the Arri S models but reiterated the situation was more of an issue with some of the Eclair cameras because it was the actual eyepiece.
Which sits right up to your eye.
Where the Arri 'S' has other optical elements in the way and more importantly distance that protects.
Maybe somebody will chime in knowing specifically which Eclair finder is the offending party.
Probably should buy a geiger counter anyways though!
Edited by Eric Niemi
there is no way to know without a geiger counter so it would be wise to purchase one anyway ?
there is couple of types of viewfinders for the Eclair cameras and I think the CP16R finders fit them too. All of them cannot be radioactive ?
I just bought an Angenieux viewfinder for my CP16R and it's yellowish when looking through it. Reading this thread I'm not liking the situation..
If it is radioactive, is there a way to de-radioactive it?
Edited by Robino Jones
  • Upvote 1
I have used viewfinders created for the CP-16r on the NPR and they work fine but not the other way around. How did the Angeniuex work for you?
Viewfinders for the Eclair NPR and the CP-16r can be used interchangeably, but they don't fit the Eclair ACL without modification.
I just ordered from Amazon the same radiation meter Aapo uses. It might arrive next week. I'll check my ACL 1.5 Angenieux viewfinder (and other vintage glass I own) then and post my findings.
Still, I find it difficult to believe that the viewfinder would have radioactive elements. After all, thorium hasn't turned radioactive only now, it has been that always, right? ACLs were popular cameras for documentary makers -- countless hours of eye on that viewfinder!
I tried to find out about cameras having radioactive eyepieces. Thus far I have been unable to find anything on Google. Such eyepieces have been used in old military equipment, which has been repurposed by some for use on microscopes or telescopes.
Some sources say that using those elements in eyepieces is against regulations. How long those regulations have been in use I don't know, but I'd like to think already in the 1970s one wouldn't have been allowed to put radioactive elements right next to camera operator's eye. Then again, asbestos wasn't banned in many countries until 90s...
But we'll see. I'll post my findings.
Although the Angeniex Eclair NPR viewfinder does fit the CP-16R, from my experience, it doesn't work properly on that camera and isn't optically suited to it.
Has anyone had better luck with it on that camera?
I don't know that it'll reduce radiation but I've heard of people reducing yellowing in optics, particularly lenses by having them in sunlight for prolonged periods. Maybe leave it in windowsill for a few weeks...
I know, I own the same viewfinder that you have on the picture and a couple of the nice and orientable viewfinders for the CP-16r. The CP viewfinders work fine on the NPR, but the Angenieux doesn't work properly on the CP-16r.
That's a reality. I used to have a Super Takumar 50mm f1.4 that had a yellow tint. You can put the lens under the sun rays, but you have to wrap it using aluminum foil so it doesn't heat. In my case I used an Ikea desktop lamp that is known to have a lot of UV rays and it did clean it.
  • Upvote 1
It works great, brighter and slightly bigger image. Also keeps the image up right in any orientation.
But now I'm not sure I want to look through it ?
  • Upvote 1
Let me revise myself here: apparently some Pentax 6x7 viewfinders do have thoriated glass. Which seems utterly incomprehensible. https://www.flickr.com/groups/328006@N25/discuss/72157675944465082/
  • Upvote 1
I forgot to add. There is one issue. For my eyesight I can't get it to focus correctly using the diopter range  -5, 0, +5, but if I put my contact lenses then it's fine. I also had a friend look into it and he has perfect 20/20 vision, he was able to focus it but had to be +5.
I'm ok with this since I wear contacts, also it might be my viewfinder that needs an adjustment..
Thanks for checking this out. It's appreciated. We should all buy a geiger counter and make a list of sorts and keep it updated!
8 hours ago, Eric Niemi said:
Yup. For sure it's bothersome. Who thought this was a good idea ?
Exactly. I can only think they were ignorant then about the effects of radiation on humans. I had thought that ended in about 1960. I have memories as a kid of having my feet Xrayed in shoe shops, sometimes 3 in one day ?
Edited by Doug Palmer
remove word
surely they knew about the radioactivity. but the issues caused by the thorium use are limited to the manufacturing of the glass unless someone really wants to grind down photographic lenses to dust and inhale it.
making high refractive glass is not that easy and one needs this type of glass for at least some of the lens elements for the design to be effective and practical enough to manufacture.
it was the same with why asbestos was used so extensively: it is a wonderful building material (great thermal and acoustic insulation, tolerates lots of heat, has good strength and can be used to reinforce many types of materials like ceramics and plastics. it is even relatively cheap and easy to mine and process) . It only becomes an issue when it starts to generate fine dust and people inhale it. I would be perfectly happy having a huge chunk of asbestos on my kitchen table if it would be sealed in glass so that it could not spread any dust around ?
I actually collected some uranium glass beads some years ago, mainly for their nice green fluorescence under UV light. Uranium glass is safe too unless one grinds it down to dust and inhales it...
Edited by aapo lettinen
According to some information I read, thorium use has been restricted in the US since 1963. For lenses it has been authorized but for eyepieces not. Some unauthorized use has been, but I also read a comment online from a camera enthusiast who had measured hundreds of cameras and only that Pentax VF has had this issue.
Considering this I find it highly unlikely that Angenieux would have done it in the latter part of 1970s. Had cinematographers developed cataracts due to radiation, that would have been a real mess in courts, I'd guess. And would French laws on radioactive materials have been any more permissive than US ones at that point?
  • Upvote 1
Surely someone has a Geiger Counter and can test some eyepieces to enlighten us.
ok I can volunteer purchasing all those 'radioactive and highly dangerous' Eclair ACL cameras from you with their viewfinders. I have just the right garage to store them in a lead lined box of sand with all my uranium glassware and hydrochloric acid bottles.
Let's say,  100 USD a piece for the camera body and the viewfinder plus some mags?  It's a good deal for you all really because you won't shoot anything with the cameras anyway now when having the slightest suspicion that there MIGHT be something radioactive in them ?
#videotapsavestheday
  • Haha 3
Yeah, perhaps this rumor is finally able to bring down those Ebay prices ?
My geiger meter should arrive on Tuesday or more realistically later next week. I'll post the information here... unless, of course, I want to buy a cheap second unit ??
Nice! Thanks so much and keep us posted!
Look forward to your findings. I think probably the only danger to health may lie in the eyepiece lenses, if they are found to be radioactive. And radioctivity basically lasts forever.... I hope others in the still-photography community do their tests as well.
A good subject for a documentary perhaps ?
For a lengthy time following the banning of atmospheric nuclear tests (Kodak eachtime warned ?)  many businesses didn't think small amounts of radioactivity  presented any danger maybe. Even now, I do wonder if airport xray operators are safe.
add word
Thinking about the cameras and lenses, surely the manufacturers would have considered the detrimental effect on the film itself ? Even if no thought for camera operators ?
