F.S. Arri Maxima MX30 QL Gold Mount 3-Axis Motorized Gimbal Pro Set
Rick Anderson
  • Site Sponsor
$32,000
Arri Maxima Itemized Kit List Vibration Isolator 1-Wrench 1-Low Profile Mitchell Tie-Down 1-Large Washer 1-Nut Maxima QL 1-Arri Maxima MX30 QL Gold Mount 1-Top Holder fo Maxima QL 1-Mounting Plate for Maxima QL 1-Arri Pan Lock for Maxima MX30 QL 1-Mitchell Mount for Spider 4-Mitchell Mount Screws 4-Arri Cone for Spider 1-Arri Cone Receiver for Spider 1-Arri Top Handle for Maxima QL 1-FoMa Systems Maxima Remote 1-Foma Systems Antenna for Maxima Remote 1-Arri SAM-3 Stabilizer Adapter Mount 1-Arri Stabilizer Plate 1-Arri Long QL Plate 1-Arri Short QL Plate 1-FoMa Maxima Baseplate 1-989gm Weight 1-326gm Weight 1-159gm Weight 1-96gm Weight 4-1 1/2" to 1 1/4" Speed Rail Shim 2-Speed Rail Shim 1-Cinemilled Maxima Tie Down Washer 1-Cinemilled Maxima Tie Down 1-1 1/2" Speed Rail Clamp 1-1 1/4" Sped Rail Clamp 2-Maxima Hoist 1-Microsoft Surface Go 1-Microsoft Surface Go Protective Case 1-Arri Tie Down for Mitchell Mount for Spider 2-Arri RMB-3 Rod Mounting Bracket 1-Assorted Spare Screws and Parts 2-DJI Ready Rig Quick Connect 2-Alexa Mini / Amira Power Cable 2-12v 4-Pin XLR Power Cable 1-Alexa 2-Pin Fischer 1-Surface Go AC Power Charger 2-Surface Go USB-C to USB Mini 4-Instruction Manuals 1-Klein Tools Torx T10 PLC Wheels 1-PLC Wheels Tilt Module 1-PLC Wheels Pan Module 1-PLC Wheels Roll Module 1-PLC Wheels Power Switch 1-PLC Wheels Mounting Plate 1-PLC Wheels Battery Plate 1-PLC Wheels Radio for Maxima 1-Antenna for Maxima Radio 1-PLC Wheels Spektrum DM8 2.4 Ghz Radio for Movi 1-PLC Wheels Futaba TM-8 2.4 Ghz Radio for Ronin 1-PLC Wheels USB Serial Data Cable 1-PLC Wheels Spare P-Tap Power Cable 4-PLC Wheels Interconnect Cable 1-PLC Wheels Mitchell Tie Down PLC Wheels 75mm Tie Down Ready Rig 1-Ready Rig Vega Vest With Lumbar Support Upgrade 1-Ready Rig Left Shoulder 1-Ready Rig Right Shoulder 1-Ready Rig Wrist Support Straps 1-Ready Rig Carrying Bag 2-Ready Rig Adjustable Telescoping Arms
Edited by Rick Anderson
Change
Link to comment
