Dirk DeJonghe Posted July 26, 2022 Share Posted July 26, 2022 I need to film a computer screen, about 2K -4K resolution. The footage is at 25 fps; I am trying to use an external sync box (from PAL days) but cannot shift the phase so my film frame starts at the same time as the digital frame, giving a half frame dissolve instead of a clean cut; Any suggestions how to handle this? Link to comment Share on other sites More sharing options...
Robin Phillips Posted July 26, 2022 Share Posted July 26, 2022 is it a modern LCD? if so, make sure its running at a higher refresh rate, ideally at a frame rate divisible by 25. My experience has been that when shooting 24 fps, on a tv or LCD running at 60htz or higher theres no real issue shooting a TV screen without a sync box. This comes from the LCD holding on a given frame for a few cycles before it changes (when your video on the display is fewer fps than the monitor refresh rate). On one rear projection job (projector was running at 120htz) we considered plugging the camera and projector into the same circuit to phase jam them that way, but it wasnt necessary (this was with an alexa on battery). For... reasons... the source video playback was actually at 30, but there was no artifacting or anything weird on the final shot. If you have a DSLR or even an iphone handy, do a test filming the monitor you want to use. if the refresh rate is high enough you probably wont have any issue. 1 Link to comment Share on other sites More sharing options...
Premium Member David Sekanina Posted July 26, 2022 Premium Member Share Posted July 26, 2022 I can confirm, when shooting modern LCDs and OLED screens I had no rolling bar or other artifact like on a CRT. check around the 3m25s mark: 1 Link to comment Share on other sites More sharing options...
Premium Member Tyler Purcell Posted July 26, 2022 Premium Member Share Posted July 26, 2022 I've shot many LCD displays with my Aaton and never had an issue. 1 Link to comment Share on other sites More sharing options...
Dirk DeJonghe Posted July 27, 2022 Author Share Posted July 27, 2022 The problem is to have the film camera in phase so that the first frame of a new shot on the screen comes clean on the negative and not a mixture. Link to comment Share on other sites More sharing options...
Premium Member David Sekanina Posted July 27, 2022 Premium Member Share Posted July 27, 2022 I see. For frame by frame shooting you would need a capping shutter - and only works if there is nothing else moving in the shot. This is a silly idea, but if it's a short sequence, shoot it multiple times. The image change has to happen during the 180 degree transport phase of the film, so there's a theoretical 50 50 chance. So when you shoot let's say a 5 second scene 5 times, hopefully in one of the shots, the image change happens during the dark 180 degree transport phase. Yeah it's a crude and silly idea ? Link to comment Share on other sites More sharing options...
Joerg Polzfusz Posted November 21, 2022 Share Posted November 21, 2022 When your camera has an electrical remote release for single frames like a Super8-camera, then you can use the CineAssist: http://cineassist.filmcurl.com Link to comment Share on other sites More sharing options...
Mark Dunn Posted November 21, 2022 Share Posted November 21, 2022 On 7/27/2022 at 7:15 AM, David Sekanina said: it's a crude and silly idea ? It's not- it's a variation on how we were told to do it at film school. Just blip the start button a few times until you see the flyback bar close to the top (or bottom) of the screen. The mirror and film are 180deg out of phase so the bar will record at the bottom (or top) of the screen. Link to comment Share on other sites More sharing options...
