Andrew Johnson Posted August 12, 2022 Share Posted August 12, 2022 PLC Veracity - 3 Axis Remote Wheels - with Slice The Veracity Control Wheel System is a fully stand-alone wheels solution for RC camera applications. The system connects wirelessly to the head, Movi, DJI Ronin, ARRI SRH-3, Maxima and Trinity etc.. with no added latency. Veracity is designed to be powered by any common on-set DC power source and has intuitive gear ratio and direction controls. Custom CNC machined handwheels mounted on precision shafts with ultra high resolution encoders provide for smooth operation and perfect balance. All this is packaged in a sealed rugged aluminium housings with flexible mounting options. These wheels I have mounted on black a plywood board with 3/8 holes in bottom ready to be attached to a stand or whatever you like. Complete with: - 3 Axis wheels mounted on black plywood board. Gold Mount / Anton Bauer battery mount with power switch. Slice transmitter (Spektrum) installed. - USB regulated power output unit. - Spektrum DX trainer cable. - PLC programming / calibration cable - USB - Spare Orange Transmitter module. (note: 2pin Lemo power input is pin 1 +ve, pin 2 GND!) PLC Veracity Manual and programming instructions included. USD $4800 ono. email: ajcam ( at) me.com Ph: +61 414620249 Andrew 'AJ' Johnson Link to comment Share on other sites More sharing options...
Andrew Johnson Posted August 20, 2022 Author Share Posted August 20, 2022 bump Link to comment Share on other sites More sharing options...
Andrew Johnson Posted August 29, 2022 Author Share Posted August 29, 2022 make an offer! Link to comment Share on other sites More sharing options...
Andrew Johnson Posted September 29, 2022 Author Share Posted September 29, 2022 bump... Link to comment Share on other sites More sharing options...
