Kyle Farscht Posted August 25, 2022 Posted August 25, 2022 I was trying to figure out what the output equivalence of the Aperture 600D or 1200D is to a comparable HMI. Like is the Aperture 1200D at full blast more output or less than a 5K Frensel? Online I can see that the 1200D max power output is 1200W but how does that compare to traditional non-LED HMI's? I'm very lost, so if you have any thoughts please add them 1
Nicolas POISSON Posted August 25, 2022 Posted August 25, 2022 (edited) Comparison is always a bit complex since there are two parameters: the overall luminous flux (in lumen) and the luminance at the centre of the beam (in lux). A very narrow beam can reach an impressive value in lux, but will be unusable because it is too narrow. Even when the angle of two beams is the same, that does not mean the falloff are the same. A very approximate rule of thumb would be to consider that a LED source is twice more efficient than a HMI with equivalent angle and optics (like a Fresnel lense). A 600W LED would more or less correspond to a 1200W HMI, and a 1200W LED would match a 2500W HMI. That may be a little optimistic, though. I doubt a 1200W LED could compete with a 5k HMI. Do not get too impressed by the marketing fashion trend that sells the LED technology as "THE ONE" with high efficiency. HMI also has high efficiency compared to incandescent, and has been used for decades now. By the way, the Aputure does not "output" 1200W, it "draws" 1200W. And all HMI are "non LEDs". Edited August 25, 2022 by Nicolas POISSON 1
Premium Member Phil Rhodes Posted August 26, 2022 Premium Member Posted August 26, 2022 I have some Aputure 600-watt LEDs available right now, so if you want any measurements done I'm happy to oblige. Generally they seem powerful because, with the high-gain reflectors, they are effectively PARs. It's a high-efficiency layout. They do quite well with the spotlight adapter, too, because the profile lens tube is pretty well designed and nicely put together. There is an argument that Aputure's fresnel isn't quite large enough and perhaps fails to capture as much of the light output by the COB as it could, though it's not clear how much difference that makes compared to a 575W HMI with its small lens. It's worth noticing that all of these things are actually more to do with the adaptors that go on the front than the light itself. The point is that it's relatively easy to gather all of the light that comes out of the LED module because it isn't radiating light into a near-spherical pattern. It's easier to push the photons in a useful direction. The system is less lossy. As such, these modern LED designs are all likely to be more efficient, watt for watt, than HMIs, for no reason other than that they let people create more optically efficient designs. The absolute efficiency of an LED with reasonable colour quality is probably not that much larger than an HMI, although for me the deciding factor has to be cost. An Arri D5 575W HMI PAR with ballast is more than twice the price of an Aputure LS 600C, and the 600C is a full colour mixing, dimmable, interchangeable-modifier light that can in a pinch be run from batteries. Expensive batteries, sure, but it can be done. I would also say that the 600D Pro (which is the beefier, better-built, roadworthy version) and the 600C Pro are both reasonably representative of Aputure upping its game and targeting a higher end clientele. On that basis, I wonder if some of the big players in this industry will go the way of, say, DaVinci, which gurgled down the plughole with a shriek of "but we're high end, this can't happen to us!" 1
Albion Hockney Posted August 26, 2022 Posted August 26, 2022 3 hours ago, Nicolas POISSON said: A very approximate rule of thumb would be to consider that a LED source is twice more efficient than a HMI with equivalent angle and optics (like a Fresnel lense). I don't find this to be true. LED to HMI efficiency seems pretty similar. I find the 600d close to as bright as a joker 800 a 1200D is like an M18 bulbed with a 1200W bulb...again maybe a touch less? 2
Premium Member Jay Young Posted August 26, 2022 Premium Member Posted August 26, 2022 On small shows, I don't bother renting Jokers, especially the 400 anymore. If I need larger lamps, I'll get M18's or M40's. The 1200D is not an M40. However, for general use case, while the Joker 800 is probably brighter in the lab, real world use case the 600D can achieve the same thing. However, they go really green much faster than an hmi globe. 1
Premium Member Aapo Lettinen Posted August 26, 2022 Premium Member Posted August 26, 2022 The main advantage of Leds is that they are lighter weight and faster to setup for not needing long warming/cooling time to function. Often they are much easier to manage flicker with and it is fast and easy to adjust dimming without many drawbacks. The biggest disadvantages are short lifetime and thus large burn hour costs on leds (a led fixture like aputure normally lasts only two or three years before the leds are aged tol much to be usable and then you need to buy a new light) , the fragility of the fixture as well as cables and connectors, the possible fan noise which is more difficult to manage for coming from the light itself rather than the ballast, and the less punchy light especially on high power fixtures because led has much larger surface area compared to similar power hmi or even triple power hmi. One additional drawback is donut shaped artifacts in light when shooting a high power mirror reflector led through a cookie or three branch etc to break up the light. The mirror reflectors create very weird light quality and one can expect some issues if needing to break the light beam this way
JB Earl Posted August 31, 2022 Posted August 31, 2022 Jay, how many hours do you think to get obvious green on the big COB leds? Do you think it's from the heat, such that instruments like mats wouldn't experience it as much? I always have bad color mismatch on rented HMIs....
JB Earl Posted August 31, 2022 Posted August 31, 2022 The 600D has about as many useful footcandles as a 2k Blonde. Modifiers notwithstanding 1
Premium Member Phil Rhodes Posted August 31, 2022 Premium Member Posted August 31, 2022 On 8/26/2022 at 10:46 AM, aapo lettinen said: The main advantage of Leds is that they are lighter weight and faster to setup Everything you say is absolutely right, with the possible exception of this. Most LEDs are light and fast, but the really big, high-power LEDs are getting pretty chunky. A full Aputure 600C kit weighs more than twice what an Arri 575W HMI fresnel does, although the HMI doesn't come in a nice padded rolling case. The 600C does a lot more but it is not a featherweight either in the lamp head or the ballast. Part of this may be due to Aputure very clearly beefing up its build quality, probably in the knowledge that these things are much more targeted at a higher end market. Of course it's also less than half the price of an Arri D5, which is an increasingly absurd reality.
Premium Member Aapo Lettinen Posted August 31, 2022 Premium Member Posted August 31, 2022 1 hour ago, JB Earl said: Jay, how many hours do you think to get obvious green on the big COB leds? Do you think it's from the heat, such that instruments like mats wouldn't experience it as much? I always have bad color mismatch on rented HMIs.... high operating temperature at least speeds up the aging a lot though it will happen in lower temperatures too. the phosphorus on the leds ages and that causes most of the colour issues. Led mats can heat up quite a bit too if operated at higher power levels. If the cob led has a proper cooling system then I would expect the lifetime being about the same compared to a mat which is operated at nearly full power most of the time. On a shoot a year ago we had couple of Aputure 300d's which were a little over a year old then and were almost unusably green already. They were only used on two feature projects I think so the aging can indeed be incredibly quick. Though properly cooled high quality leds should last a bit longer, maybe two or three years before the green becomes so large issue that one needs to throw the light away. With HMIs one can always change the bulb if it is bad colour and one can match bulbs too. But on a LED the light source is built into the (expensive) light and cannot be changed to new one so it is not like changing a 100usd HMI bulb but one needs to purchase a whole new 2000usd light instead. That is pretty risky by my opinion so I am personally being extremely careful if purchasing any kind of led technology so that I can be sure I can get the money back from it before the light ages too much to be usable. So one needs to get the money back from it in less than a year to be sure that there is no huge risk purchasing one. It is the same with today's camera technology though, one can manage only about two years max. with the same camera body and after 4 years it is probably broken and unusable... 2
Premium Member Aapo Lettinen Posted August 31, 2022 Premium Member Posted August 31, 2022 52 minutes ago, Phil Rhodes said: Everything you say is absolutely right, with the possible exception of this. Most LEDs are light and fast, but the really big, high-power LEDs are getting pretty chunky. A full Aputure 600C kit weighs more than twice what an Arri 575W HMI fresnel does, although the HMI doesn't come in a nice padded rolling case. The 600C does a lot more but it is not a featherweight either in the lamp head or the ballast. Part of this may be due to Aputure very clearly beefing up its build quality, probably in the knowledge that these things are much more targeted at a higher end market. Of course it's also less than half the price of an Arri D5, which is an increasingly absurd reality. the weight of the lamp head matters more than the weight of the ballast. If the lamphead is lightweight one can manage with a less sturdy and thus much more lightweight stand and one needs less sandbags as well. The possible issue with Cob led units is that the ballast to head cable is often extremely short and thus one must often mount the ballast to the light stand to get it high enough to make up for the too short cable so that the light head can be get high enough for the shoot. That is actually a huge issue with some led units, especially the Aputure Cob leds. Too short cable so that one cannot get the light high enough because there is no enough cable for it and one would need to mount the ballast high up on the stand to be able to manage the shoot. Darn Chinese saving couple of bucks by cutting the cables shorter ? The 600d head is pretty optimal weight and size for general use. Haven't used the 600c which might be heavier and bulkier. 575Hmi with electronic ballast may be pretty ideal size and weight. With a magnetic ballast it is way heavier than a similar output led kit and slower to setup. I personally use magnetic ballast 575's because got couple of them for very cheap... electronic ballast kits are still too expensive most of the time to really compete with leds
Franklin De Los Santos Posted January 5, 2023 Posted January 5, 2023 Let’s not forget the joleko, I can probably get just as much output with it than having to buy a new light like the aputure 1200d. I’d rather stick to buying a new bulb for $150.
Premium Member Jay Young Posted January 24, 2023 Premium Member Posted January 24, 2023 To answer some questions, after three shows using nothing but Aputure products, I can say that if one already owns HMI lamps, use them. They still work. My current show I have 4x joker 400w, and 4x joker 800w - they have never been out of the case. The DP insisted that we have them...... wasted money. The Aputure and Nanlight 1200w lamps are factually the same output as an M18 at about 30% cheaper to purchase. But there are drawbacks: The header cables have a finite length, of which I have sent my disdain to the engineering department. They advise there is too much voltage drop over distances longer than 25 feet to efficiently run the led engines. Well, I call bullshit on that. Engineers are always a wee bit conservative. They will figure it out. With a ballast and lamp head the size of the 1200w fixture, there is plenty of room to shove more lighting in. I don't know how many hours it takes for one of these lamps to color shift appreciably, because they are so new it has not happened yet. I own 4 600D's, and a 1200. They work all the time, and I have yet to see, on camera, an issue. This may have been an issue with older lamps, but the new hardware is pretty solid. Now we can argue that an 800w joker with spotlight attachment puts out more footcandles than an equally outfit 600d, but I would argue that one should choose the right tool for the right job. I am sure there are Gaffers and DP's which would need the extra few footcandles in certain situations where the output difference would make or break a shot. However, I'm not so certain that it would make all that much of a difference. Things will continue to evolve and the engineering will get better. Something must absolutely be done about the F35 fresnel, which is WAY too heavy, and creates serious danger problems on set. Anyhow, Aputure, at least for now, seems to be headed in the right direction.
Edith blazek Posted November 1, 2023 Posted November 1, 2023 On 8/25/2022 at 5:35 PM, Kyle Farscht said: I was trying to figure out what the output equivalence of the Aperture 600D or 1200D is to a comparable HMI. Like is the Aperture 1200D at full blast more output or less than a 5K Frensel? Online I can see that the 1200D max power output is 1200W but how does that compare to traditional non-LED HMI's? I'm very lost, so if you have any thoughts please add them If we were comparing bulb to bulb, the 1200d is brighter than a 1200w hmi by over 10000 lumens (126413 for aputure and 110000 for 1.2k) but falls short of an 1800w hmi bulb, of which can be found with 165000 lumens. Now practically it's not as simple but that's on the luminous efficacy bit
