Raymond Zrike Posted November 20, 2022 Share Posted November 20, 2022 What amount of weight do you think is okay for PL mount before you need support? I’m wondering if I should use support for a Canon 7-63mm on an SR3. The lens is about 4.5lbs. I’ve used support for lenses in the 6.5-8lb range before, but I’m curious where it flips over to not being a concern anymore. It’s my own camera, so I’d like to keep the mount in good shape. Link to comment Share on other sites More sharing options...
Robin Phillips Posted November 20, 2022 Share Posted November 20, 2022 I always use lens support on my LWZ.2 on my SR3 and Aaton. its only a 4.4lb lens, but its a bit front loaded and if you clamp on a matte box with filtration... basically its worth it to reduce the frequency of needing the flange depth checked and reset frequently from a long heavy thing applying pressure to the mount. Im a sharpness freak on 16 so part of always using the support on zooms is just to reduce the chance Link to comment Share on other sites More sharing options...
