Marcos Cooper Posted December 11, 2022 Share Posted December 11, 2022 I lucked into a 100mm ƒ/2.3 Baltar at a charity shop and while the exterior and iris seem fine, the glass is dusty and likely has fungus—so what do I do now? I'm in Florida, is there a lens expert down here that people like? Should I take it directly to one of the specialists in Hollywood? Can I take it apart myself and clean it out? All the packages I've received from Fedex and UPS lately have been pretty much destroyed so I don't really feel like sending it across the country is a good idea right now. Also, what lens mount is this? The lens doesn't seem to have a focusing module, so I assume I'll need an adapter to use it on my mirrorless Nikons. Is adaptation even possible? Thank you for your help. Link to comment Share on other sites More sharing options...
Premium Member Simon Wyss Posted December 11, 2022 Premium Member Share Posted December 11, 2022 Bell & Howell Eyemo mount from model 71-C on Link to comment Share on other sites More sharing options...
Premium Member Dom Jaeger Posted December 11, 2022 Premium Member Share Posted December 11, 2022 First off, if you are not experienced in lens service I would not recommend trying to service or clean this yourself. The mount is for a Bell & Howell Eyemo, a little similar to Arri Standard but not quite the same. The inner part at the rear, with the cut out for a locating tab, rotates when you focus. Or more accurately, the inner part is held by a locating tab in the camera and the outer lens mount and focus barrel rotates as you focus (like some early Cooke lenses in Arri S mount). Here’s a thread on Eyemo lenses: https://cinematography.com/index.php?/forums/topic/11379-eyemo-lenses/#comments Unfortunately they are not easy to adapt, but this might make a good rehousing candidate. I would recommend selling it on for rehousing, where it can be professionally cleaned at the same time. Link to comment Share on other sites More sharing options...
Marcos Cooper Posted December 12, 2022 Author Share Posted December 12, 2022 I was afraid that would turn out to be the case. Thanks to both of you for your advice and information. Link to comment Share on other sites More sharing options...
