Johanan Pandone Posted January 18, 2023 Share Posted January 18, 2023 Hey guys, We're slow here at the shop where I work. (winter slump) I have access to a mig welder, drill press, some taps/dies and a band saw. I was thinking of fabbing up some little bits and peices that could come in handy for rigging. maybe start with making some wall plates that have an 3/8" nut welded to them that I can easily screw a baby pin or other receivers into? What are some other peices that are simple to make with the equipment I have listed? 1 Link to comment Share on other sites More sharing options...
Baltasar torcasso Posted January 19, 2023 Share Posted January 19, 2023 i made my own kit of flags.. just for fun actually Link to comment Share on other sites More sharing options...
Johanan Pandone Posted January 19, 2023 Author Share Posted January 19, 2023 10 hours ago, Baltasar torcasso said: i made my own kit of flags.. just for fun actually what method of construction did you use? Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted January 19, 2023 Premium Member Share Posted January 19, 2023 Have to say, that's what I'd do. Aren't they usually just bent and welded steel rod? You'd want the right grade of steel so it had the right degree of rigidity. P Link to comment Share on other sites More sharing options...
Premium Member Aapo Lettinen Posted January 19, 2023 Premium Member Share Posted January 19, 2023 On 1/18/2023 at 11:05 PM, Johanan Pandone said: Hey guys, We're slow here at the shop where I work. (winter slump) I have access to a mig welder, drill press, some taps/dies and a band saw. I was thinking of fabbing up some little bits and peices that could come in handy for rigging. maybe start with making some wall plates that have an 3/8" nut welded to them that I can easily screw a baby pin or other receivers into? What are some other peices that are simple to make with the equipment I have listed? flat alu frames (for example 3x3 ) would be pretty nice to make if welding the aluminium would not be too difficult. for wall plates etc stuff, I would look for something which is handy but not easy to get from stores. maybe even designing your own or making some wild experiments? Link to comment Share on other sites More sharing options...
Robert Hart Posted January 29, 2023 Share Posted January 29, 2023 You might like to examine bridges which allow two cameras to be mounted to a single tripod head. I made one out of 7/16" aluminium flatbar with plain holes for the camera base screws and a threaded hole in the centre for the tripod head's own thumbscrew/tensioner. Captive waisted base thumbscrews for the cameras would be better. For that you would need to used 3/8" flatbar, threaded camera base screwholes and a half thickness clearance for the threads of the screws in the top halves of the holes. My application was to use it to mount a wide-view sighting camera and a narrow-view camera with a 1000mm lens for agile display aircraft in flight. Other folk might use it to mount a lamp and camera. Link to comment Share on other sites More sharing options...
