bolshevik Posted March 6, 2006 Share Posted March 6, 2006 i just telecined my super 16 film to digibeta. and made a dub to dv cam. the digibeta looks great. the dv cam sucks. I think this post about sums up exactly what I mean.. You show yourself in your true light.. Link to comment Share on other sites More sharing options...
Premium Member Stephen Williams Posted March 6, 2006 Premium Member Share Posted March 6, 2006 i just telecined my super 16 film to digibeta. and made a dub to dv cam. the digibeta looks great. the dv cam sucks. Hi, How was the copy done? If made via SDI it should be good, not perfect as the compression between the 2 formats is different. Stephen Link to comment Share on other sites More sharing options...
Premium Member John Mastrogiacomo Posted March 6, 2006 Premium Member Share Posted March 6, 2006 Hi, How was the copy done? If made via SDI it should be good, not perfect as the compression between the 2 formats is different. Stephen I have made copies of 35mm transferred to DigiBeta to DVCAM and then run them through a switcher and split the screen and you cannot tell the difference. (Transfer via SDI, Thomson Broadcast 9200 switcher, DVW-A500, DSR1500A, all new tape, etc.) Now if you want to do some CC with the DVCAM footage that will be a different story. :) Link to comment Share on other sites More sharing options...
Premium Member Stephen Williams Posted March 6, 2006 Premium Member Share Posted March 6, 2006 I have made copies of 35mm transferred to DigiBeta to DVCAM and then run them through a switcher and split the screen and you cannot tell the difference. (Transfer via SDI, Thomson Broadcast 9200 switcher, DVW-A500, DSR1500A, all new tape, etc.) Now if you want to do some CC with the DVCAM footage that will be a different story. :) Hi, A lot depends on the shot. Shoot a bicycle wheel turning with a tartan background and you will see the DVcam compression. Stephen Link to comment Share on other sites More sharing options...
