Sign in to follow this
Guest Ningun
AGDVX100P to edit
Guest Ningun
When I shoot in 24p with the new Panasonic, the scene files - F5 24, F6 24 advanced - tell me I'm shooting in 24. But when I capture in either Final Cut Pro or Avid XpressPro, the only options are for 23.987. Is this the same thing? I'm new at DV (in past I used 16film) and don't want to commit a lot of time doing the wrong thing.
Dave
davidroehm@hotmail.com
www.ningun.org
Share this post
Link to post
NTSC runs at 29.97fps, and because the DVX records out to NTSC, its 24fps stream must be at 23.987fps to "match." These not-quite-whole-numbers are called "Drop Frame."
Thus, importing at 23.987fps would be okay, since the actual stream is running at that speed.
Share this post
Link to post
Alvin,
Please correct me if I'm wrong. I thought the DVX-100 recorded on NDF 'only' while in 24p mode.
Is that wrong?
Share this post
Link to post
I did some googling on the topic, and half of the websites say that the DVX actually records at 23.98fps to comply with NTSC standards, since the signal on tape is not a 24P stream, but rather your standard NTSC signal consisting of 24fps with 3:2-pulldown.
However, other websites claim that the camera actually records NDF in order to "comply with 24P standards," whatever that means.
Now I'm just confused. But really, would it make all that big of a difference capturing a NDF signal with DF settings? I haven't really looked into it since it's not a problem I've had to deal with.
Share this post
Link to post
23.97 refers to the speed of the frame rate only and that's what the DVX100 records. Drop Frame and NonDrop Frame have to do with the counting of the timecode and having nothing to do with the actual frame rate. In 24p (actually 23.97) the camera only uses NonDrop timecode so that the numbers are a continuous stream, making for easier frame flagging if one wishes to extract the 24 individual progressive frames from the 60i signal.
One can have many frame rates and they can be in Drop and NonDrop timecode. This is a very common misunderstanding.
Share this post
Link to post
Ahh, thanks for clearing that up, Mitch. :)
Share this post
Link to post
http://www.adamwilt.com/24p/index.html
This shows the main difference between the Standard and Advanced modes of the dvx100. Also more information on the capture rates/modes.
One thing I alway keep in mind is that the "DV" codec is not flexiable like other computer video codecs. The bitrate that DV runs at is a constant and connot be change, so look at it like a filmstock, you can record what you want to it, but the imformation will recorded to file in the DV formating. This is because video compression is handled by a Digital Signal PRocessor that is pogrammed to do only one thing very well. So all image processing needs to be done before it hits the DV DSP, comformed to DV's 30i (or 60i depending how you look at things) standard, and is output to tape. When footage is recorded to tape in Advanced mode, it is the NLE plug-in that mothodically removes extra "blank" information from the DV data stream.
It is only recently that JVC has started to include a new file format that can be written to mini-dv tape with its HDV camcorder.
Share this post
Link to post
Magic Bullet Software
I have used the Magic Bullet Software and it does a very cool job of creating a film look. The software looks at your video as if it were origenally shot on film; by de-interlacing the footage, performing a reverse 3:2 pulldown, then adding color filters and other aspects to the image based on prameters you select from thier library of settings. This plug-in was orgenally created to assist people doing high end compositing and solve other post production problems that come from using consumer DV footage. One thing to keep in mind is that by using the Magic Bullet and then going back to DV tape, you are going to recompress all your footage which is already compressed 5:1, so you might increase your compression artifacts in the final footage. This may or may not be a problem for you, depending on how good video gear you are displaying on is.
A
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Media Blackout - Custom Cables and AKS
    The Original Slider
    G-Force Grips
    FJS International
    Just Cinema Gear
    Cinematography Books and Gear
