Cordell Thurman Posted November 4, 2007 Share Posted November 4, 2007 hi, i'm trying to do an installation with a film (8mm or 16mm, doesn't really matter) but i need it to loop. i'm having a hard time finding a projector that is able to do this...if you are selling or know a good place to check please let me know. thank you. cordell Link to comment Share on other sites More sharing options...
Premium Member Chris Keth Posted November 4, 2007 Premium Member Share Posted November 4, 2007 How long would the loop be. Link to comment Share on other sites More sharing options...
Premium Member Hal Smith Posted November 4, 2007 Premium Member Share Posted November 4, 2007 Any manually threaded projector should be able to play a short loop as is, just splice the loop together and thread it on the projector. For a long loop you could construct a 16mm platter system that works like a commercial theater's 35mm endless loop platter projection system. Go to www.film-tech.com, navigate to film-tech forums, select search, and search for 16mm platter. You'll get a page full of postings on the subject. Link to comment Share on other sites More sharing options...
Site Sponsor Robert Houllahan Posted November 5, 2007 Site Sponsor Share Posted November 5, 2007 hi, i'm trying to do an installation with a film (8mm or 16mm, doesn't really matter) but i need it to loop. i'm having a hard time finding a projector that is able to do this...if you are selling or know a good place to check please let me know. thank you. cordell I did this recently with a eiki 16mm projector and about a 20' loop which was just fed out the back of the projector to a rewind with a reel on it, this is a common way to make a loop of varying lengths, I know of a few people who have done this across a room for a longer loop length.... -Rob- Link to comment Share on other sites More sharing options...
Premium Member John Sprung Posted November 6, 2007 Premium Member Share Posted November 6, 2007 Back in ancient times, before ADR, looping was done using real loops, which is how it got the name. There were loop racks and loop boxes with lots of rollers to thread. Most of that stuff hit the landfill a couple decades ago, though. A lot of it was custom made by machinists, not a mass produced factory product. You could probably build your own, just using a bunch of rollers from LaVezzi. Most any projector will work, you just need to build the rack for it. -- J.S. Link to comment Share on other sites More sharing options...
Cordell Thurman Posted November 18, 2007 Author Share Posted November 18, 2007 ok...great! i appreciate the responses...but why do i need manual over automatic? how does that really mess stuff up? thanks...cordell Link to comment Share on other sites More sharing options...
Nick Mulder Posted November 18, 2007 Share Posted November 18, 2007 ok...great! i appreciate the responses...but why do i need manual over automatic? how does that really mess stuff up? thanks...cordell Manual, you can thread the loop intact - automatic, you have to carry the projector around with the loop in it or cut the splice and redo it once you've loaded it again... Once you get a projector it'll all make sense ;) Link to comment Share on other sites More sharing options...
Premium Member Chris Keth Posted November 18, 2007 Premium Member Share Posted November 18, 2007 In other words, an automatic projector needs an end of film in order to thread. Since a loop has no end... Link to comment Share on other sites More sharing options...
Mark Dunn Posted November 20, 2007 Share Posted November 20, 2007 I think you can usually thread an automatic projector by hand if you really want to- my Super-8 Elmo you certainly can, it's just a bit fiddly, and you have to be careful not to scratch the film. But if you're buying a projector specially, and old manual might be cheaper anyway. I would probably put spools on the projector and then lay the film over top of the spools to guide it. If it needs to be quite long, you could run it carefully into a pillowcase in a big waste bin, rather like on an editing table. A fair length of film will behave itself quite well handled in this way. I'd certainly trust, say, 50' of film in a bin. But it really does need to be attended. Link to comment Share on other sites More sharing options...
Jess Haas Posted November 21, 2007 Share Posted November 21, 2007 Elmo made a loop attachment for their super8 projectors. If you can find one it should do exactly what you want. I have seen them on ebay before but that was a number of years ago. ~Jess Link to comment Share on other sites More sharing options...
Mark Dunn Posted November 21, 2007 Share Posted November 21, 2007 One of these. The ST-600 is a decent projector, by the way; mine is going strong (with a new belt) after 28 years. But for that very reason they can be quite expensive on ebay. That will show a whole 400' film, 20 minutes or so. Your loop probably isn't going to be that long, so the idea of a bin might suite you better. Link to comment Share on other sites More sharing options...
