Sign in to follow this
abdul jamal
lomo lenses
i have few extra lomo oct-19 lenses for sale if anybody interested .
2-75mm t.1.6 -both 1987
2-50mm t1.5 -1989 and 1985
1-28mm t1.5 -1987
1-28mm t2.2 -1988
1-22mm t2.2 -1979
1-18mm t2.9 -1989
1-50mm t2.2 -1982
all lenses are free of fungus ,scrathes or anything that will affect your
pictures .
let me know which set you're interested in or if you just want one lens with offer .thanks
Share this post
Link to post
Are they geared?
I may be interested in the set, any thoughts on pricing? Thanks!
Bruce Taylor
Share this post
Link to post
Are they geared?
Bruce Taylor
Hi Bruce.
The LOMO OKS lenses with OST-19 can have two versions of gears.
The lenses from set of Kinor-35 H camera have gear with small step between cogs.
The lenses from set of Konvas-2M camera can have gear with big step.
If you need, i can measuring and tell you size of steps.
If you have lenses with Konvas-2M type of gear and wish have of small step gear ( Kinor-35H type ), the lens can be modifi.
The other type of ring with gear ( Arri step ) can be install too.
Share this post
Link to post
Hi Olex.
Does the 22mm and the 28mm fit the Kinor?
Could you post some pictures
Share this post
Link to post
Sorry About that
Hi Abdul.
Share this post
Link to post
I am interested but as always it comes down to how much you want for them. What do you want for them?
you need to let me know which set are you interested in or maybe you're want all of them .
Share this post
Link to post
The set of Kinor-35 H lenses have 22 mm and 28 mm lenses.
You can have of Konvas version of body of lens with " lead" at rear side of lens.
This lens can be not compatible with Kinor-35, because have big size pf parts from rear side of lens.
I recomed you to build of profile of surface of inside of Kinor and check with rear profile of your lens.
I can help you to do this. Or send me picture of your lens.
The next, need check of distance between rear glass of lens and plane of film.
Kinor-35H limit of this distance on 18.5 mm, Konvas have limit 13.5 mm.
Share this post
Link to post
If the price is right, sure, I'd be interested in them all. Make me you best, smokin' deal and let's see if we can deal or not. :D
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Serious Gear
    G-Force Grips
    FJS International
    Just Cinema Gear
    Cinematography Books and Gear
