Eclair flickers... help!
Patrick Barry
Also, FYI. I've had all kinds of trouble with M42 to C-Mount adapters with my Eclair ACL. That oscillating mirror reflects that huge still 35mm lens image circle all over the place. The problem is entirely eliminated with 28mm Switar or Zeiss Super16 prime lens.
Link to comment
  • 2 weeks later...
I have been doing some further research on this issue. First of all, the shiny gate: that problem was there even before the conversion to S16, I just hadn't realized it. I thought they were only some funky lens flares by Switar. As for the adapter, that's probably the chief cause of large internal reflections as many of you have mentioned. As a first remedy I used some black tape as a light baffle -- no reflections anymore.
As for the flicker I'll know if it was only caused by internal reflections quite soon. I have shot some B&W test material which should be processed and telecined tomorrow. However, if there is still some flicker my next step will be disconnecting the clapper light and LEDs.
As you can see in this photo http://s9.postimg.org/r69v7n8qj/f032702.jpg there is a narrow unaffected area on the right hand side of the screen. One ACL owner contacted me and told he had bad flicker problems as well and supplied me an example screenshot which had that same narrow area on the right hand side. His problem turned out to be related to the clapper light and the fix was just disconnecting it -- as surprising as that sounds.
Anyway, it seems these flicker problems (or the shiny gate) aren't that uncommon at all with S16 Eclair ACLs:
Even here, 00:25
Are there any S16 ACL users who do not have this issue? :)
Link to comment
What are we looking for in that first clip. I watched to 1:51, trying to guess, then gave up.
Flicker on the left hand side flare, 00:06
Gate flare, 01:23
Flicker on the left hand side upper corner, 02:15
Flicker on the left hand side flare, 02:55
Flicker and gate flare, 03:27-03:36
Link to comment
I had seen both of these clips before... I definitely think the first one (which seems to be mostly lens flare associated) is due to a large image circle lens. It's definitely a disadvantage of the oscillating mirror design of the ACL.
Well, if it's only the image circle causing problems with flares it's rather easy to work around. To quote myself from an earlier message in this thread:
I guess I'll just have to refrain myself from trying to emulate the look of the new Star Trek movies
And since that problem shouldn't be there with my Switars (10mm and 16mm) I guess I can also do some flare-y vimeo hipster clips -- I just can't use SLR lenses or 75mm Yvar for that purpose ;)
But soon I'll know more.
Link to comment
What an interesting issue... just read through the whole thread.
Any reflective surface can cause this issue, including a mirrored shutter reflecting light back at the lens for a brief moment during its rotation. So I always look at things like viewfinders and video taps as the leading culprit. Sometimes lenses have decayed coatings and built up mold which is hard to see with the naked eye. So light reflects strangely through the glass and hits the shutter, which then reflects back at the lens for a brief moment, causing that blip. Sometimes with a dark room and a flashlight, you can mimmic these issues. But unless you know what to look for, its hard.
I haven't shot with the Eclair's before, but I've seen this phenomena on the Cinema Products mirrored shuttered cameras like the CP16R. But we tracked it down to a lens coating issue. Switch lenses, problem went away.
Never had issues like this with my SR's or Zeiss primes I use to use.
Link to comment
The results are in!
First of all, I got to say ORWO UN54 looks absolutely beautiful in S16 processed as negative. :)
Now then, for your viewing pleasure (please watch in HD to see all the flickery fun):
So what was this shot with?
1. Switar 10mm
2. Yvar 75mm
3. Contax Zeiss 28mm, light baffle from black tape
4. Contax Zeiss 50mm, light baffle from black tape
5. Contax Zeiss 50mm, light baffle from black tape and the internal filter removed
Second half of the film was shot with Zeiss 50mm and Switar 16mm (most of it).
Now then, flicker. It is in weird places, such as the first clip which is shot with 10mm Switar that only barely covers S16 frame. What's even more difficult to understand is why there is such a clear rectangle there that is flickering and overexposed compared to the right hand side of the frame?
Well, it could be just light doing something weird within my camera but exhibit #2 -- 4:55. Switar 16mm. First there is this exposed rectangle of flicker and then it just ... disappears? Same happens in 5:22.
Add to this the fact that even though I have some really strong lens flares, the flicker isn't in those flares unlike in the "Magic Summertime". Instead it is that box, like in 00:43.
Well, now I feel rather confident that this problem is solved by removing the clapper light. Oh and come to think of it, I did play with the clapper switch during shooting the second part of this film...
Link to comment
The results are in!
1. Switar 10mm
2. Yvar 75mm
At 4:55 and 5:22 something seems to happen to the camera... like the loops are caught or something. Notice that the image itself is almost jittery looking but then suddenly stablizes at the moment the flicker goes away.
I'm kinda starting to question your magazine and if your film is completely engaging flush against the gate...
Link to comment
At 0:58... see how your lens flare cover the whole film area... not just the image frame? That tells me light is getting around the edges of the gate to the covered areas of the film... either that, or the shutter timing is off so the film is advancing with the shutter still open. But you would usually get a smear in that case.
Link to comment
For the record, here's the earlier clip which I haven't yet posted here:
https://www.youtube.com/watch?v=M82igSqcOlI
I have shoot footage with my three different magazines:
400ft, another 400ft and one 200ft. Of those three mags I had problems with one and had it serviced during the S16 conversion of the camera. Let's call those mags mag A (serviced 400ft), B (400ft) and C (200ft). The film I posted in October was shot with C. The film I posted yesterday was shot with A (first part) and C (second part). The film in this message was shot with B (first part) and A (second part).
Link to comment
Now I'm officially proud of myself. Last week I decided to test the fix involving disconnecting the clapper lamp.
Well, if something can go wrong it probably will. Disconnecting the whole connector set going to the leds and the lamp was quite straightforward. I have opened my camera base several times. This time, however, for some reason I wasn't able to connect the motor when putting the camera together. That 9-pin connector didn't want to connect. It was surprising, but considering that someone before me had cut some parts of it because the connector in the motor was also a little broken (the shell around the pins), looking back, it wasn't really that surprising.
So there I was, trying desperately to connect the motor. And then it happened: one of the sockets in the camera twisted and broke. It was really a moment every camera owner whose camera tech lives in a different country doesn't want to live through. Especially since I soon found out that those Cannon ITT connectors -- which are still produced and used! -- aren't that common and easily obtained. Almost nobody had them available despite having them on their catalogues. Thank you Eclair for using special military spec. connectors intended for aviation and space operations!
Somehow I was able to find an almost 1:1 replacement part and order with two other connectors from the US for $150. Today I received it and after some five hours of first chipping parts of plastic from the connector to make it fit and then carefully soldering all the wires going to the old connector to this new connector's wires I have my camera running again. Lesson to be learned: be really careful with your old milspec connectors...
As for the flickering, I decided to cut the clapper lamp wire. While doing that I measured the voltage going to the lamp. Pushing the clapper switch made it jump. However, what's really interesting is that there was a little amount of voltage even when the clapper was disabled from the switch. I wouldn't really be surprised if the amount of voltage is just enough to affect the film. But we'll know for sure quite soon: now that my camera is up and running again, I'll shoot some tests tomorrow and have them processed and transferred by the end of the week.
Edited by Heikki Repo
Link to comment
Hey Heikki,
Those 9 pin Cannons for the motor to camera connection. ACL service people may often have these in stock. A short while ago following a tip from Andrew at AZSpectrum I contacted Paul Scaglione at Visual Products and they were $25 each, with tails, as Eclair must have origionally ordered them. Did you check with Les B?
Coming back to flicker causes. I don't know if the rubber drive block is causing anything, but it is an easy thing to eliminate. If ordering parts, get one and then forget that. Looking for causes (what causes something) can be very complicated. Change one little thing, and suddenly another thing is enabled. The S16 conversion may enable other factors to come into play.
Link to comment
  • 2 weeks later...
Back to square one:
At the moment I'd be really happy if I just found out where that exposed "window" is coming from. Yesterday I spent about an hour in a dark room with a bright led flashlight + a piece of paper taped to the gate area. I tried my best to find the internal reflection that would paint a light rectangle on the frame while still leaving out that narrow very clean cut area on the S16 area of the frame. I didn't find anything. There is nothing inside the camera that would make a clean cut narrow area of shadow on the frame when light is bouncing around.
That is to say, at the moment I'm not really that interested in the cause of flicker. I'm interested in the cause of that weird rectangle of light. Since the cause isn't the blooper light, I have to continue looking for the cause.
Next up:
- New tests with the whole viewfinder inside a black bag to rule out all viewfinder related light leaks (in my opinion this is at the moment the most probable cause since it fits with the very bright daylight and the viewfinder could reflect a rectangle shaped area of light on the film frame. Also, I'm having problems with all lenses. Even when I'm using that 10mm lens that same rectangle flicker seems to appear...
- New tests with black paper taped over the mirror to rule out problems not related to the mirror
BTW, this test was shot with AGFA Aviphot 200 / Wittnerchrome 200D. I like the look.
Link to comment
That's definitely the best looking AGFA 200D I've seen yet. It's just too grainy in Super 8 but that looks pretty good in Super 16.
I don't see why, but I still say that the source of this square flicker/window that only occurs during spots of bright light (such as a the sun) being at just the right angle... is light reflecting off the ground glass. This problem looks very similar to when you take your eye way from the eyepiece without first closing the eyepiece shutter.
Link to comment
Heikki, I don't have an Eclair but that light rectangle reminds me of a similar-looking effect I used to get enlarging stills in the darkroom. I spent hours and hours trying to find the fault. Then one day I noticed a really tiny round pin-hole where the lens-mount was attached to enlarger. It was creating its own large faint rectangular image.
  • Upvote 1
Link to comment
You just need a sunshade.
Tube, compendium, matte box, flag, anything that cuts off light outside the image rectangle before it can reach the innards of that camera
First half of the material was shot with those Contax Zeiss lenses with long lens hoods. Despite that there is still that odd light...
Link to comment
Heikki, you've probably checked already, but carrying on from this is there a pin-hole leak in the viewfinder optics somewhere?
Well, that's something I'm about to check by putting the whole viewfinder inside a black bag during next tests :)
Link to comment
Have you considered masking the gate down to 4:3 and running tests?
I ask because you suggested this problem only started after the Super16 conversion.
If the problem went away with a masked gate you would know that it definitely is related to the actual conversion.
I noticed there is a strip of film to the right of the frame that seems unaffected by the flares. Is this the Super16 area?
Freya
Link to comment
