Guest Eric Szyszka Posted March 5, 2004 Share Posted March 5, 2004 I'm a first time poster here and I have a couple of questions. I am planning on directing and shooting a short film this summer on miniDV probably with a Canon GL-2. I want to establish a Film Noir look to this film because it involves a classic femme fatale, among other reasons, and I want to turn it B&W anyway. I've been a huge fan of Film Noir for a long time and there's a moment I've got written into the film of self-reflexive voice over. For this I want to illuminate just the eye region of the character leaving everything else relatively dark. There is a shot like this in Detour (1945). How should I go about doing this and other kinds of lighting for my film? Most locations will be interior and there'll be a shoe-string budget so I don't think I can run out and buy anything extremely extravagant. Thanks so much for reading. - Eric Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted March 5, 2004 Premium Member Share Posted March 5, 2004 You need a light that creates a hard, sharp shadow. You can create that strip of light by cutting out a rectangle in a piece of illustration board or foamcore board and then shining a light through it, at enough of a distance from the board to project a sharp pattern of light on the face. Link to comment Share on other sites More sharing options...
Guest Eric Szyszka Posted March 5, 2004 Share Posted March 5, 2004 Thanks, David. I had originally suspected the rectangle might be a way to do it but I wasn't sure and decided I should ask people with more professional knowledge than myself. I am mostly a writer. Link to comment Share on other sites More sharing options...
Premium Member Michael Nash Posted March 5, 2004 Premium Member Share Posted March 5, 2004 You need a light that creates a hard, sharp shadow. You can create that strip of light by cutting out a rectangle in a piece of illustration board or foamcore board and then shining a light through it, at enough of a distance from the board to project a sharp pattern of light on the face. You can also use a small mirror the same way. Take a piece of 12" mirror tile and mask it with black paper tape to the shape/size slit you want. Just as with the foamcore technique you need enough distance between the light and the "stencil" to make the shadow edges sharp. Mount it firmly in a C-stand with a gator grip. It's basically the same idea, it just allows you to get a little more distance in a confined space, and sometimes it's easier to precisely angle just the mirror. Of course Dedo lights are prefect for this also, but the mirror/stencil technique is easy on a low budget or if you don't happen to have Dedo's in your lighting package. Link to comment Share on other sites More sharing options...
