HeikkiPekka Vaara
Newbie: Battery for ACL II
Maybe the easiest way is just to get or make a short cable with 4 pin XLR at one end and Lemo or whatever you choose at the other.
Best option, agreed.
Share this post
Link to post
Yeah but I still have Jaeger on my body, so XLR does not really make sense...
C
Share this post
Link to post
4 pin XLR is the usual power connection on 16mm film cameras. but there's no reason why you have to convert you camera if you don;t want to. It's pretty standard on batteries (unless you're going to use a video camera battery), so worth having one on your battery. Also worth having two power cables, since they can break at inconvenient times.
Share this post
Link to post
Before the ACL II it was Jaeger on the camera and 4 pin XLR on the batteries, then with ACL II it was reversed with 4 pin XLR on the camera. So the same power cables work for both. I assumed that Carl had a standard ACL power cable with a 4 pin XLR on the batt end, but maybe he does not. Worth picking one up, will be cheap used. Maybe someone on the forum has a spare...There were long spiral cables in the earlier days, then short straight ones came for the onboard batteries.
Share this post
Link to post
I actually have 2 cables with jaeger contacts. And Jaeger batteries. Not XLR.
But if any 12v will work, my cable guy can probably make a jaeger to D-tap cable.
C
Share this post
Link to post
I thought I'd add to this discussion, I have got one of these batteries; It's 12 volts, it's small and light, I bought it off ebay, it works pretty well for my ACL II.
Pav
Edited by Pavan Deep
Share this post
Link to post
My plan is to go from D-tap from V-mount to Cannon 4 pin. I'm either going to use the original camera mount that runs along side the mad or devise something else.
Share this post
Link to post
The standard on board mount, IMO puts a lot of stress on screws for that little casting at the back of the camera, which may not matter, not sure, but I never liked the idea. If you can customise something, for example just lets you velcrose a light battery against the mag or mount the battery on the side of the rod base etc, I think it's a good idea....
EDIT: Shedding the onboard battery is a good idea, just having it on a belt or a sling over your shoulder. Makes the camera lighter. The ACL II is getting heavy, so it helps..
Edited by Gregg MacPherson
Share this post
Link to post
Anyone knows if technically you could run the ACL of a Anton Bauer VCLX battery?
I am thinking of making my Eclair a production camera for a short in the spring, and together with a video assist, that could be a killer idea. Only problem would be running a lot of it.
I am open to attaching a gold mount / V-mount as well to run it, but I am not sure it will work as good.
C
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • CineLab
    FJS International
    G-Force Grips
    Just Cinema Gear
