Markus Mentzer Posted November 1, 2015 Share Posted November 1, 2015 Selling one of my three Paralinx Arrow-X Receivers. Can be matched to any Paralinx Arrow-X transmitter (up to four receivers). Includes an AB female plate, and metal support plate. Two 3G SDI outputs. Barely used. Normally retails new for $2,700 plus tax/shipping. Serial numbers shown in pics. Selling for $2,000 USD plus shipping. Please contact by email: markusmentzer@gmail.com The Paralinx Arrow-X System is a revolutionary HD Video Transmission system offering Realtime Wireless HD with robust long range for your Television, Film, Broadcast, Industrial or UAV/UAS application.The Paralinx Arrow-X transmits full-HD 1080p/60 with a range of up to 700 feet (215m) with default antennas (longer range possible with optional antennas) and still maintains an incredible sub 1ms latency glass-to-glass. The Arrow-X receiver features 2-Pin Lemo power connectors capable of a wide 7-17V unregulated input voltage and dual 3G-SDI video outputs. Much like the popular Paralinx Tomahawk, the Arrow-X transmits Full-HD video (up to 1080p/60 4:2:2) with less than 1 millisecond delay and is capable of handling up to 4 simultaneous receivers. The receiver weighs 12 oz/340g (without antennas). Arrow-X receivers can be purchased for MSRP US$2,499.95 each. Battery plate, antenna, mounting, power cable, and case options are available as accessories. Arrow-X Receiver Features: Lightweight Minimalist design for reduced payload Dual 3G-SDI outputs Rugged ABS enclosure Long-range transmission - Up to 700 feet (215 meters) * REAL-TIME viewing - Less than 1 millisecond latency Uncompressed full-HD video signal allow critically accurate monitoring Multicast capable (up to 4 receivers per transmitter) 128 bit AES Encryption - Secure transmission Operates on 5gHz frequency band Conforms to major technical and environmental standards including FCC, CE, MIC (TELEC) and RoHS Specifications * Range may vary depending on environment and interference Dimensions (US): 5" x 5.6" x 1.3" (not including antennas) Dimensions (EU): 143mm x 128mm x 33mm Weight: 12oz / 340g (without antennas) Link to comment Share on other sites More sharing options...
