Andrew Mackintosh
We sell dimmers for incandescent lamps, 3 different models. The smallest one up to 3kW (able to work with an Studio 3000W)
The bigger one (at the moment) is up to 7kW with double output. 16A + 32A plugs and the dimmer works with two lamps at the same time (up to 5kW + 2kW lamps)
The Flicker Dimmer is up to 3kW and it has the capability to generate flicker for special effects
The small dimmer cost £99, for more info you can check it in the website
www.strikedimmers.com
Link to comment
