Sign in to follow this
Mark Kenfield
FS: Ultimate Sony F35 Kit
Hey guys,
If you’re reading this ad, you might be familiar with the F35’s recent resurgence thanks to the wonders of modern external recorders. The sensor is just gorgeous, a 5k CCD with a global shutter (so you never need to worry about rolling shutter skew again), beautiful colour science, and highlight handling that’s still only topped by the Arri Alexa. I generally rate the camera at 400 ISO, but am happy with it up to 800 ISO (which is basically equivalent to the Red Dragon with the Skintone/Highlight OLPF).
I recently returned from shooting a Bollywood feature with it over in India, starring Eric Roberts. And I’ve shot a documentary, four short films and a couple of commercials with it as well, and it’s been absolutely rock solid for me.
I’d shot with the F35 in its original incarnation, and felt there were a couple of key areas I wanted to address when I assembled my own kit - and that was largely to do with the monitoring. The original Sony C30 EVF that came with the camera was only standard definition, and it made being certain of critical focus with the camera pretty difficult, it also only gave you zebras for exposure monitoring, which again, was pretty limiting. So my solution was to pair the camera with the new Zacuto Gratical Eye, and the Odyssey7Q+. This gave me HD monitoring with both the EVF and the monitor/recorder, with full, customisable LUT support across both (something most of the current top cameras out there still won’t do), and waveforms, (accurate) peaking, and false colour (to name just a few of the features).
I’ve installed matching LUTs on both the Gratical and the Odyssey, and calibrated both to match (so you’ll see a matching image regardless of which you’re looking at).
The reason I consider this the ‘Ultimate’ F35 kit, is because I’ve designed every part of the kit with the Operator (namely myself) in mind, and as a result it’s really easy to work with. The build is extremely streamlined, with a 15mm rod system allowing for rigid and precise placement of both the EVF and the monitor. The Zacuto Axis Mini slots straight into the Wooden Camera Top Handle, and allows for perfect placement of the EVF for handheld work as well as being on the dolly or sticks. And because the Top Handle is mounted to Nato Rail, both the handle and EVF can be slid off the camera in mere seconds for packing down into a compact carry case, or squeezing into tight spaces. Every component just works really well together.
To simplify things further I also had Panavision build a custom v-mount plate for the camera, to provide two addition DTAP ports to run the Gratical Eye and the Odyssey - which means there’s no stuffing around with DTAP splitters or additional battery/power-distro gack.
Using the Odyssey7Q+ allows you to get the most out of the sensor possible, using dual-link recording from the camera’s Interface Box, you get an uncompressed 12-bit 4:4:4 1080p feed (downsampled from the 5k sensor), that you can record in uncompressed 12-bit .DPX files (for insane image quality), or 12-bit ProRes4444 or ProRes4444XQ (for simple, very high quality drag-and-drop files). Or for shoots that don’t require crazy image quality you can also record in simple ProRes422 or 422HQ. You can also record at up to 50fps for beautiful 2x slow-motion. And with two 512GB Samsung 850 Pro SSDs, you’ve got enough recording space to comfortably shoot for a full day.
The camera only has 1230 hours on it, so it’s about as pristine an example as you’re going to find.
Additional kit includes a Portabrace Rain Cover/Sunshade for the Odyssey7Q (which is great for viewing the monitor outdoors), and an Element Technica Hybrid Studio Baseplate and Dovetail, along with 19mm stainless steel rods - so you can put the camera straight on your tripod, add a battery, add a lens and start shooting immediately. There’s nothing left to add with this kit, as I’ve already put in the hard yards to design and piece it together. and the nice part about the kit, is that because all of the accessories are non-proprietary, they'll translate over seamlessly to your next camera too.
The full kit list is as follows:
- Sony F35
- Sony F35 Interface Box
- Sony F35 L-Handle
- Sony F35 Assistant Panel
- Odyssey7Q+
- 2x 512GB Samsung 850 Pro SSDs
- Portabrace Rain Cover/Sunshade for Odyssey7Q
- Zacuto Gratical Eye
- Zacuto Axis Mini EVF Mount
- Wooden Camera NATO Handle (Plus)
- Berkey System 15mm Rods and Spuds for Odyssey7Q
- Element Technica Hybrid Studio Bridgeplate (19mm Rods)
- Element Technica Standard Arri Dovetail
- Stainless Steel 19mm Rods
- Custom V-mount Battery plate with 2x DTAP
- Convergent Design DTAP to Odyssey7Q cable
- Zacuto Braided LEMO/SDI cable for Zacuto Gratical Eye
- 2x Canare 3G-SDI Cables for dual-link recording
- Custom Flight Case
The camera is located in Melbourne, Australia, but I’m happy to ship worldwide.
Price is $9,500 USD + shipping
(I’ll need to add 10% GST if it’s purchased in Australia)
Share this post
Link to post
And here are a few grabs from some of the projects I've shot with it:
Edited by Mark Kenfield
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Paralinx LLC
    G-Force Grips
    FJS International
    Just Cinema Gear
