Stuart Brereton Posted April 18, 2018 Share Posted April 18, 2018 I think it's been stated that other cameras with much smaller bodies manage to accomplish more impressive data rates. Again, unless I didn't read the tech specs properly, the internal data rates are no more than an FS7 which is an entirely different class of camera. XAVC Class 480 produces very big files, and that amount of data is overkill for a lot of productions. Yes, it's the same codec as in the FS7, but that's because the FS7 punches well above its weight in this regard. Link to comment Share on other sites More sharing options...
Premium Member Mark Kenfield Posted April 18, 2018 Premium Member Share Posted April 18, 2018 I thought only the F5 and F55 did XAVC Class 480, isn't the FS7 limited to the original Class 300? Link to comment Share on other sites More sharing options...
Stuart Brereton Posted April 18, 2018 Share Posted April 18, 2018 I thought only the F5 and F55 did XAVC Class 480, isn't the FS7 limited to the original Class 300? I thought the FS7 had been updated as well, but apparently not. Class 300 is still pretty good, though. The bitrates on the 480 are enormous. Link to comment Share on other sites More sharing options...
Randy Rubin Posted April 19, 2018 Share Posted April 19, 2018 Isnt the bit rate for Class 480 , ~400 mbs 10-bit? Is ProRes 444 @ UHD ~1000 mbs 12-bit? Im not questioning the quality of the FS7 or the codec. Im just a little confused why a top-of-class ~$50,000 cinema camera body maxes out at 10-bit, 400 mbs when competitors like the Arri Alexa Mini and Red Epic-W and Weapon manage higher bit depth and data rates in smaller bodies. Link to comment Share on other sites More sharing options...
Robin R Probyn Posted April 19, 2018 Share Posted April 19, 2018 Class 480 is 480Mbs at 24/25/30.. and 960 at 50/60.. Yes fs7 doesn't have 480 (yet?).. I guess the idea was if you want 16 bit you add the A7.. it fits on without any cables and could be considered "one" camera body .. Venice is pretty small body.. way smaller than the Alexa or LF.. its more compact than an Amira come to think of it.. Link to comment Share on other sites More sharing options...
Randy Rubin Posted April 20, 2018 Share Posted April 20, 2018 Class 480 is 480Mbs at 24/25/30.. and 960 at 50/60.. Yes fs7 doesn't have 480 (yet?).. I guess the idea was if you want 16 bit you add the A7.. it fits on without any cables and could be considered "one" camera body .. Venice is pretty small body.. way smaller than the Alexa or LF.. its more compact than an Amira come to think of it.. I didn't realize Class 480 went up to 960 for high speed. I think it's an exciting looking camera. I know the body is smaller than an Alexa or LF. But it only does 10-bit without the recorder. With the recorder it's about the size of an Alexa or Amira. Maybe if they enable recording to an Odyssey for 444 or RAW that'll alleviate some of my concerns. That way I can mount the recorder to a gimbal if needed. Link to comment Share on other sites More sharing options...
Robin R Probyn Posted April 20, 2018 Share Posted April 20, 2018 I didn't realize Class 480 went up to 960 for high speed. I think it's an exciting looking camera. I know the body is smaller than an Alexa or LF. But it only does 10-bit without the recorder. With the recorder it's about the size of an Alexa or Amira. Maybe if they enable recording to an Odyssey for 444 or RAW that'll alleviate some of my concerns. That way I can mount the recorder to a gimbal if needed. Doesn't have to be high speed .. just plain 50p/60p.. will do it too.. I think this about the max for XAVC.. yeah still think its going to weigh less though.. I wonder if there is a cable for the R7.. so you can mount it as you suggest.. there should be.. Link to comment Share on other sites More sharing options...
Brian Drysdale Posted May 22, 2018 Author Share Posted May 22, 2018 Here is the first of a series of videos on the Venice: Link to comment Share on other sites More sharing options...
Robin R Probyn Posted May 22, 2018 Share Posted May 22, 2018 Thanks Brian.. does seem to be a great camera.. maybe Sony will actually have a camera that will maker some inroads into the high end feature world..which the f65 never really did.. the menu is actually very similar to the one that was introduced in V9 of the f5/55.. for the LCD panel .. I wonder if they were sort of trying it out.. Link to comment Share on other sites More sharing options...
Premium Member Adrian Sierkowski Posted May 22, 2018 Premium Member Share Posted May 22, 2018 It really does look like a nicely done little camera (though I would argue it's an F55 ver2). Hopefully i'll be able to play with it a bit on set as I rather like the stuff sony puts out. Link to comment Share on other sites More sharing options...
Premium Member Miguel Angel Posted May 22, 2018 Premium Member Share Posted May 22, 2018 Guys, it is an amazing camera. The only thing that it misses is false colour (apparently it is going to be implemented in August), other than that is, simply put, fantastic. Have a lovely day! Link to comment Share on other sites More sharing options...
Robin R Probyn Posted May 22, 2018 Share Posted May 22, 2018 It really does look like a nicely done little camera (though I would argue it's an F55 ver2). Hopefully i'll be able to play with it a bit on set as I rather like the stuff sony puts out. But being a FF sensor I dont see it as a F55 V2.. although they of course deny it.. it has to be more of an F65 V2.. its the exact same market its after.. I don't see the shutter thing being the big difference that Sony claim.. but I could see Sony combining the f5 and 55.. with the fs7 the f5 is sort of falling between two chairs .. time for an f8 !!.. Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted May 22, 2018 Premium Member Share Posted May 22, 2018 Remember how big the Dalsa Origin was? Link to comment Share on other sites More sharing options...
Robin R Probyn Posted May 22, 2018 Share Posted May 22, 2018 Yeah its an incredibly well put together design.. it looks like you want to work with it.. Link to comment Share on other sites More sharing options...
Brian Drysdale Posted May 23, 2018 Author Share Posted May 23, 2018 Part 2 video. 1 Link to comment Share on other sites More sharing options...
Brian Drysdale Posted May 26, 2018 Author Share Posted May 26, 2018 Workflow video with Venice Link to comment Share on other sites More sharing options...
Brian Drysdale Posted September 16, 2018 Author Share Posted September 16, 2018 There is an announcement of 3.0 firmware and a sensor head extension for the Venice at IBC https://www.provideocoalition.com/sony-venice-3-0-firmware-extension-head-announced/ Link to comment Share on other sites More sharing options...
David Peterson Posted September 19, 2018 Share Posted September 19, 2018 Crazy how this month marks a whole year since VENICE was announced! Guess it took a while for the camera to be developed, rolled out , and to gain growing acceptance. Link to comment Share on other sites More sharing options...
