Noise WITH F55 slog3.
Gabriel Wilson
On a recent shoot I found it to be extremely noisy in the blacks even at EI 800. I eventually ended up lifting the black levels above zero but was unable to get the contrast and ratio I wanted. That is why I am so curious how others expose there black levels. ESP such a large production.
Lifting black levels is going to make noise worse, not better. Were you in Cine EI mode? What MLUT were you using?
Link to comment
Rec709800 shooting slog3cine. Exposed with false color. I did not lift blacks- I over exposed - so blacks were no longer at 0 ire no matter what I did I seemed to get noise though. I have had this issue with the camera more than once. Curious what else could be causing it? Maybe overall exposure? But blacks at zero should not have noise?
Link to comment
Link to comment
I've never used the camera with that setup, so I don't know. I always use it in Cine EI, SLog3, ISO 800, MLUT LC709A, and expose from either the viewfinder, or a calibrated monitor. Never had a problem.
When you color-timed from the camera originals, was the noise still there, or was it just in the 709?
Link to comment
When you say you over-exposed, do you mean you were overexposing by rating the camera at 800ISO, or you were overexposing the 709 image in false color? Or both?
Link to comment
Sony's ratings for the camera can't be trusted. But if you just leave it at it's 1250 ISO 'native' setting, and use false colour to get a grey card properly exposed, you'll have no noise and plenty of latitude.
The camera doesn't need to be overexposed to be noiseless, it just needs to be exposed properly. From my tests, the bodies I've used have all been sitting around 640 ISO (on a lightmeter) in order to correctly expose an 18% grey card at 41% IRE (the correct value for middle grey when shooting SLOG3).
Link to comment
Mark, I think we are essentially proposing the same thing. As the camera is always 1250 ISO in Cine EI mode, the only difference is that you are suggesting that, as the camera is actually slower, then using false color will give you a 'correct' exposure at around 640 ISO. This is the same as setting the camera to 640 ISO (or in my case 800 ISO) and trusting the MLUT to give you a correct exposure on the monitor. Two different ways to arrive at the same place, although, if you use an MLUT, the monitor will at least look correct.
I agree, though, that the F55 is not a noisy camera.
Link to comment
I'd tend to agree Stuart.
Though I've always wondered about a bit about this approach (adjusting the EI settings on the camera). As I know you, and quite a few other people recommend it.
I never adjusted the EI settings when I've used the Sonys, because (once exposed correctly) the monitoring output has always appeared accurate to me (camera left at 1250 EI, but exposed at 640). So I always assumed that adjusting the EI value on the camera (so both setting the camera to 640 EI and exposing it for 640 ISO), I'd be looking at an outputted image that was actually a stop hotter than it should be.
Though in hindsight, since I've always been sending out the untouched log signal from the camera to monitors that I can then apply 3D LUTs to, I'd possibly not be seeing any difference on them anyway? It would just be the EVF that receives the brighter 640 EI in that situation right?
Link to comment
If you're using the Log output to judge exposure, then yes, you wouldn't see any difference. I don't use False Color, and I set exposure from the Rec709, so for me, it's important to have the MLUT compensating for the over-exposure.
Either way works, but I just don't like judging exposure from Log.
Link to comment
