Baia Super 8 Reviewer
Dan Katayama
The front cover is removalable and the bulb comes out as part of a unit. It is soldered into position and part of the assembly. So before you remove the bulb from it's position, take a digital picture of it so you can put the new one back into the exact or very similar position. The metal frame the bulb is attached to comes out as one piece. You must remove this bracket unit in order to get at the bulb. Do not try to remove the bulb from the bracket holder until you've removed it. BAIA sold replacements already presoldered into these holders, but these are getting rare to find. That being said, if you can solder, you can fit a new lamp for it. Good luck!
Edited by Martin Baumgarten
Link to comment
