Charles Deng
ARRI UDM1 mount on RED SCARLET-W
Hi everyone
The question I want to ask is that how exactly mount an ARRI UDM1 on a RED camera to get distance measure data. Do I need the whole ARRI electronic control system to support? Like UMC-4, Cforce motors etc.
Share this post
Link to post
If all you are looking for is to have the UDM readout function then no, you can set up the horns and the readout separate from the LCS. You simply need to mount both the horns and readout, connect them up and then connect the readout to an appropriate power output - D-Tap or RS.
If you want to have the UDM readout on your WCU-4 or Preston handset that is different, but it sounds like that is not what youre asking.
Share this post
Link to post
Thank you James. I can take it as a separate system am I correct? If I need readout on WCU-4 even pull the focus based on this data,do I need something else like UMC etc?
Share this post
Link to post
Yes it can be a system separated from the camera, you need the following:
WCU-4
UMC-4 + a lens motor
UDM-1
This cable to connect the UDM to UMC: http://www.arri.com/camera/pro_camera_accessories_electronic_control_system/products/distance_measure/#!view=product&pnumber=K2.65144.0
Share this post
Link to post
WCU-4
UDM-1
This will work, or also you can do:
- CForce RF Motor
- LCube CUB-1 serial convertor
- LBUS cables (obviously)
I've never ran the CForce RF motor with the UDM-1 (or ever, actually!) but either should work fine. the RF is definitely a smaller build footprint.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Serious Gear
    FJS International
    Just Cinema Gear
    G-Force Grips
    Cinematography Books and Gear
