K3 Not keeping loop. Moves up.
Robino Jones
 Share
I can't figure this out, the loop keeps going up.
See video for the issue - if anyone has any tips on solving this issue please let me know.
https://vimeo.com/288433643
Password: loop
..and PS, I know the film is not facing the right side - just test roll, i don't have a take up reel yet.
Thanks very much.
Edited by Robino Jones
Link to comment
...Update
If I roll the film around the pole that used to release the loop former, the upper loop sticks and bottom is held by that pole. It works and I checked the film for scratches, can't see any..
I'm not liking this workaround - anybody seen this before?
See pic for loop workaround.
Link to comment
That workaround is no good.. it seems you have an issue with the claw pulldown, so just pulling the film around a roller from the sprocket to keep the loop won't necessarily time the film movement with the shutter. You'll most likely end up with smeared images.
The reason the loop is moving up is because the sprocket keeps advancing the film, but the intermittent pulldown is missing a perf and not keeping the film moving through the gate at the same rate.
You need to examine the claw and gate to see why the film is not being properly advanced by the claw. It could be that the claw is somehow not aligned with the perfs, or it's worn and slipping, or the gate is contaminated and making the film stick, or the pressure plate is not closing properly to press the film against the gate and allow the claw to penetrate the perf, or some other issue like this that makes the claw skip a perf.
Link to comment
Yes that's exactly what's happening. I saw this by advancing manually and it skips a perf here and there.
I took the gate out and cleaned it very well, the claw is moving inside a hole in the gate and it is secured by 5 screws with not much play to adjust it so I'm not sure how else the actual gate could be the culprit. Maybe it is I don't have experience with this camera.
I'll have to check alignment and pressure plate.
Link to comment
First, you’re having the film laced up the wrong way. The lighter side (dull amber) must face the aperture, the shiny black side is the backing. The stock should be wound EIB, that means Emulsion In, winding B. B wind means that the holes of single-row perforated stock are on the right hand side when the spool is held vertically and the stock coming off downward near you.
Second, learn that those Soviet cameras were slammed together by workers not well trained, mostly less-well payed women. Many examples have issues. Give your camera to the hands of a camera technician. Los Angeles should offer enough in that respect. Cheers
Link to comment
I explained that in my original post.
This isn't the whole problem, but check that you have the sprocket guides closed. They should click into place.
The guides are closed and clicked - I really think the issue is with the claw as Dom said but that's beyond home repair (for me) at this point - I'll try to find someone to look at in in the Los Angeles area - if anyone has tech suggestions let me know - thanks everyone.
Link to comment
  • Sustaining Member
So yea, correct wind would be step one.
I've seen this happen with my K3, for some reason the spring that holds the pressure plate in position was super weak and the pressure plate would simply wobble all over the place and not keep the film in place. With a slight change to the position of the little cup that holds the spring, I put a tiny bit more pressure on the pressure plate and BAM problem went away.
You can always bring it by, I'm pretty good with the K3, I got mine working really well.
Link to comment
Thanks Tyler - I just tried moving the pin in and added more pressure, tried different levels of pressure but the claw is still is skipping some perfs, Maybe I should bring it - i'll call you.
Link to comment
  • Sustaining Member
Yea I can fix that in a jiff, I'm sure it's something silly.
Link to comment
  • 8 months later...
  • Sustaining Member
13 hours ago, Vladislav Evdokimov said:
I have the same problem with my K3, did you find a solution?
Sadly we never really found a solution. I got it working A LOT better, but no matter what, it would skip every once in a while. We compared it to my camera and there was NO difference. The pulldown was not pulling the film down on every rotation of the movement, but nothing indicated it being broken or out of calibration. Someday I'd like another shot at servicing it, just to see if I can get it working better.
Link to comment
Thanks for reply, that's sad.
I've disassebmled the front mechanism on mine completely, lubricated but it doesn't help either. My second K3 is new and works great, but it has m42 mount and I prefer bayonet for wide-angle lens (no planning super16).
Maybe it is possible to swap the front part completely in order to change lens mount between cameras?
Link to comment
  • Sustaining Member
Yea you could try that! Just gotta re-check the flange distance however.
Link to comment
Hi, sorry for being a little off topic by bringing my own problems into the mix here, but could anyone look at this video and tell me if the rocking back and forth of the loops is normal and if not what could be done to fix it?
any feedback would be greatly appreciated!!
thanks
Link to comment
The flange distance is different 45.46mm on M42 and 52mm on Bayonet.
I've done the swap yesterday and just by looking through the viewfinder focusing seems okay.
But I know that the tolerance for the film plane is very small and I can't check that without shooting actual film...
As for loop moving Marc I think it's normal for k-3.
Link to comment
  • Sustaining Member
That's what I kinda thought. You can go deeper into the film plane, but not the opposite way. It'll always look good in the viewfinder because you're just focusing to the ground glass. You do need to measure flange distance.
Link to comment
1 minute ago, Vladislav Evdokimov said:
Got it, I'd better find another nos k3 body or stay with m42 for now.
Is hand processing an option with kodak/fuji ecn stocks? Just for test purposes.
Nearest film lab is in another city.
Reading about your K3 issues brought back some bad loops PTSD.
Yes I think getting another body might be the solution or even better, get a Bolex equivalent, I hear they are much better.
I abandoned trying to solve the issue after I disassembled the entire thing, really getting in it and still could not figure it out what the problem was. Not worth the time. I was going to throw it down the balcony but I opted for the trashcan instead where it belongs. I kept the lens and the K3 metal plate as souvenirs.
Best of luck to you, I know how frustrating it can be.
Link to comment
The only reason why I choose k3 was because it can be found very cheap in russia and there are tons of them.
But yeah, the build quality is shitty. If I won't be dissapointed after first few rolls of film I'll definitely consider bolex or renting arri sr3 or 416.
Thanks for support! I'm on the first floor so balcony is not an option = )
Link to comment
2 hours ago, Tyler Purcell said:
Yea that's totally normal... but make your loops a tiny bit bigger.
Thanks for the quick reply!
so just to make sure, I don’t have to worry about the image looking like it’s jumping or anything right? I was just worried when I saw videos online of others loading their k3’s and their loops seemed to keep completely still.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
Forum Sponsors
Film Gears
VidGear.com - Broadcast Video Warehouse
FJS International
Cinematography Books and Gear
TripdsVideo CamerasLightingVideo Camera LensesMonitors
ADVERTISING INFO
