Richard Perrine Posted September 13, 2018 Share Posted September 13, 2018 (edited) 2 rack system of Magnatech 4000 series Magnetic film dubbers. Can run 16mm or 35mm film at 24 or 25 FPS. Setup with 16mm heads only. Rack one recorder....1 edge track record and playback. Rack two playback dubber...2 decks play 1 track each plus 16mm optical sound reader. The 3 machines lock together so you can playback 2 track and fed them to a mixer then to recorder. Each rack is 7 ft tall....24" wide...20" deep...… weight each rack 300-350 lbs Both would fit in a full sized van. $1,500.00 Also...a different 3 rack system is also available (4 track record/ 16-24 track play) pick-up here in Akron Ohio. E-mail RBPerrine@att.net Edited September 13, 2018 by Richard Perrine Link to comment Share on other sites More sharing options...
