Donald Riley Posted October 2, 2018 Share Posted October 2, 2018 Can anyone think of an ingenuous way to get a 2.35 frame into a Filmo viewfinder? Link to comment Share on other sites More sharing options...
Donald Riley Posted October 2, 2018 Author Share Posted October 2, 2018 I mean ingenious. Link to comment Share on other sites More sharing options...
Philip Forrest Posted July 15, 2019 Share Posted July 15, 2019 Which Filmo VF? 16mm or 8mm? If you're speaking of the 16mm 70 series, does it have the turret type with objectives (70DR, 70DL), the fixed viewfinder with drum-switchable diopters (70DA) or the fixed viewfinder with no diopter nor adjustment? I modified the turret in my 70DL to match the focal length of my 2.5" Kodak Anastigmat by notching the thin brass foil that forms the mask. You could either widen the mask with a keyhole file (there is plenty of room) or make the vertical axis shorter using some amazing flat, black tape then switching out the objective itself to match the lens FL. Phil Forrest Link to comment Share on other sites More sharing options...
