Brendan Collins
Arriflex 16BL - SMOKING
Hi friends. I have an Arriflex 16BL with tobin TXM-15 sync that I tried to use today. Its worked many a times before in the past. Today I hit the button to shoot; and nothing happens. What the hell? I take the mag off to see if it was jammed or something; and more smoke than cheech and Chongs car came wafting out of the gear area. Gosh darn it.
I take the motor housing off and I see this- 5amp blown fuse. Okay but where was the smoke coming from??
My inching knob is broken as well. Any suggestions? I have all the pieces.
The motor still turns by hand, have yet to get the replacement DC fuse.
Questions now
1. The motor shows 9,5V motor. I have a 12v 7.5mah battery. Direct leads to a power cable, to Tobin system. Am I over-powering the camera with this battery? Or does the tobin system have some sort of conversion from 12v to 9.5v for the motor?
2. What do you think was the cause of the smoking? Upon inspection of what I could disassemble, I see no melted resistors or plastic or wires, etc. see pictures.
3. Suggestions on replacement of the inching knob?
**** pictures to come****
Share this post
Link to post
If the Tobin controller is a 12V system then a 12V input is fine.
The smoke will most likely have been a component that melted, check all the ICs etc, something will be damaged. Might just be a black scorch mark on the outside is all you can see. Don't replace the fuse and run it again, you risk doing more damage. An electrical repair person needs to assess and repair it, unless you can do component level repairs yourself. It would be handy to have the circuit diagram from Tobin, but a good electronics tech could probably work it out and replace what's damaged.
Share this post
Link to post
Check your wiring harness.
When I worked at a Major University, we had a BL develop an internal short and the wiring from the shutter release to the motor burned all the insulation off the wires.
Not pretty.
Share this post
Link to post
Not pretty.
Do you have/know of any diagrams on the disassembly of this camera? Id be able to diagnose a burnt or melted part assuming I can gain access to the areas... Ive never worked on these cine cameras before so I dont want to just start taking things apart, especially in the blimp. Also, it says a 5amp fuse, which Id assume is a DC fuse, but I can only find 5amp 250V rather than 5amp 12V fuses... any source?
Share this post
Link to post
At these levels fuses don't have a voltage rating, just current. Get the one that fits- probably 20mm.
Edited by Mark Dunn
Share this post
Link to post
I personally do not but check with this entity via the YouTube link it they might have something:
Share this post
Link to post
Don't waste your money on a spare parts manual, as you can see from the few pages shown, it just has pictures of the many individual parts with no disassembly or service instructions. Arri didn't make service manuals for their cameras, or provide disassembly instructions. But you shouldn't need to dismantle it anyway.
You should be able to remove the Tobin motor and electronics by reverse following this installation manual:
http://www.urbanskifilm.com/TCS_Public_PDF/CHT_MOT.pub.pdf
Once removed, there won't be much electronic stuff left in the camera, and what wiring there is should be mostly visible.
  • Upvote 1
Share this post
Link to post
Hi!
It is not too difficult to unmount the camera, I've just opened a discussion where I'm completely refurbishing a 16bl. If you remove the cap and the motor (with 3 screws on the interior side of the camera) you have enough space to understand if some wires are burned. But if you want to do more, remove the blimp mount (8 screws), then unscrews the 4 shock mount and you will be free to remove the core part!
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • CineLab
    FJS International
    Just Cinema Gear
    G-Force Grips
    The Original Slider
    Cinematography Books and Gear
