Pavan Deep
Wolverine Super 8 Scanner
The Wolverine Super 8 scanner is pretty cheap and basic and I'm sure the quality is pretty mediocre. I suppose to get decent scans with it one would need a better light source, a better camera and lens inside. Just wondering if anyone has tinkered with this unit.
Pav
Share this post
Link to post
Check reviews on Amazon, B&H, and see actual results on youtube. There are many negative reviews on the output and on the functioning of the scanner. A major complaint is it only engages one sprocket at a time which leads to jams.
Share this post
Link to post
I haven't used it myself but the three main complaints were the quality of the scanned movies and breaking or jamming the film due to the one sprocket being used to advance the film instead of three sprokets used on more expensive equipment which caused people to have to rescan many times, and breakdown of the equipment. Also the warranty was only for 200 scans. One reviewer said it took more than 20 tries to scan one 3 minute piece of film. At that rate the warranty would expire after 8-10 film scans.
I thought the biggest problem was compression
Edited by Bob Speziale
Share this post
Link to post
I scanned this with a Wolverine.
nsfw
Too low Q for me.
Plus it broke after 20 something reels. Then it ate up an important film. Once it starts to squeal, stop scanning or you risk getting your film ruined.
If it was higher Q and lasted 20+ reels, then it could work even as a disposable and still be economically feasible versus paying a lot of $ to get the film scanned.
Share this post
Link to post
The ONLY good thing about this scanner is that it's affordable. Besides that, it's not meant for any type of serious preservation. I bought this when I was offered a job to scan priceless footage of Wisconsin and I ran into many problems with it: the film wouldn't be in the same place you aligned the camera when you hit the record button, the film would get stuck in the gate so I had many five seconds to hour long scans of just one frame, the recording quality was so bad I had to apologize to the client, the scanner will not play back the footage like advertised, and the list goes on and on. Unless you're just buying this to keep some footage alive, don't buy this.
Share this post
Link to post
Has anyone tried to change its camera, or lens?
Pav
Check here, I think I remember reading about a guy that modded it.
http://8mmforum.film-tech.com/
Topic Date Forum Wolverine MKPro Resolution October 18, 2018 8mm Forum Wolverine Movie Maker October 14, 2018 8mm Forum Looking for a schematic October 12, 2018 8mm Forum Wolverine Pro... what am I doing wrong? Please help! September 18, 2018 8mm Forum Comparison of Digitizing Methods, YouTube vid September 16, 2018 8mm Forum Super 8 to digital: variable speed projector best? September 14, 2018 8mm Forum Wolverine Pro uk September 07, 2018 8mm Forum Crappy Wolverine Codec? September 06, 2018 8mm Forum Telecine via Viewer/Editor August 17, 2018 8mm Forum Wolverine digital converter July 28, 2018 8mm Forum Wolverine/Somikon (etc) film scan clips May 16, 2018 8mm Forum How to Fix a Wolverine Rotation Problem April 08, 2018 8mm Forum Wolverine Moviemaker-Pro thoughts and issues March 27, 2018 8mm Forum GOKO 8mm Multi-Recording Sound Editor RM-3 Film Splicer Viewer March 25, 2018 8mm Forum New guy in the forum, question regarding Filmguard February 19, 2018 8mm Forum moviestuff.tv upgrade February 04, 2018 8mm Forum Questions about 8mm to digital January 24, 2018 8mm Forum Digitize Sound from 8MM? December 17, 2017 8mm Forum Super 8mm film to digital. November 23, 2017 8mm Forum Jumping back into Films. November 17, 2017 8mm Forum New Toy! Chinon 2500GL Variable Speed October 17, 2017 8mm Forum Noris Norisound 512 take up reel September 25, 2017 8mm Forum Wolverine September 25, 2017 8mm Forum Wolverine MovieMaker randomly stops August 31, 2017 8mm Forum Winait, My email-thier reply' August 30, 2017 8mm Forum Reflecta Super 8+ scanner August 10, 2017 8mm Forum Wolverine Film2Digital Moviemaker digitizer: Focus problem May 19, 2017 8mm Forum Somikon HD-XL Film Scanner & Digitizer (Super) 8mm - EU market May 13, 2017 8mm Forum Film scanner: Retro/MovieStuff/Flash vs Wolverine/Somikon May 01, 2017 8mm Forum Possibly stupid question about green film April 28, 2017 8mm Forum New Wolverine Digitizer problem April 26, 2017 8mm Forum Wolverine April 22, 2017 8mm Forum review Wolverine Reels2Digital MovieMaker 8mm film digitizer April 01, 2017 8mm Forum Family 8mm movies February 08, 2017 8mm Forum Digitising Film January 12, 2017 8mm Forum Wolverine film2 digital hack September 05, 2016 8mm Forum
Share this post
Link to post
BH used to have a super 8 scanner that looked like a movie projector. It was about $1200. It had good reviews, but they don't seem to sell it any longer.
The movie film scanner options are terrible for anyone that is on a budget. Really sad industry has not filled this niche.
Edited by Daniel D. Teoli Jr.
Share this post
Link to post
Too bad they didn't make this one in higher res. I heard they were decent scanners.
https://www.ebay.com/itm/MovieStuff-Retro8-8mm-and-Super8-Film-Scanner/183486607073?hash=item2ab8a76ee1:g:Wx4AAOSwOuBbtYZg:rk:3:pf:0
A lot of these film scanners seem to be made in some guys garage. I don't care about that, as long as they are affordable, reliable and produce decent scans.
Share this post
Link to post
I received a Wolverine 8mm scanner as a gift. It's plugging away right now on a reel. Before even looking at the quality of the scan, what I notice is the amount of time it takes to actually scan a 50' reel. Like 1-3 seconds per frame. It advances the frame then adjusts the frame to line up properly before scanning then moving to the next frame and repeating.
You must have a ton of time on your hands to use this thing.
My goal is just to scan some reels for reference before choosing what to send out for real scans.
It does have a switch to handle negative film which is a positive (pun intended) but really honestly it's just for knowing what's on the film...and an 8mm viewer would be much quicker. But if you can put it in a separate room (the constant clicking will drive you crazy) and let it do it's thing then a crappy little reference scan isn't so bad.
The other minor plus is that it is very easy to use...
Share this post
Link to post
Ok, I take all that back, It's a complete piece of crap. Initial scans looked like some kind of Monet painting with constant jitters.
Maybe I have a bad unit, but it's going back tomorrow...gift or not. :angry:
Share this post
Link to post
Just have it exchanged. It produces low end usable images. You may have got a bad one.
Yes, good for previewing / deciding on what to send out to get done. Also gives you something of a back-up if your original gets lost in the mail. You set a timer when doing reels and come back near the end. No need to sit there. Although if there is an issue and it jams, it will eat up the sprockets.
Share this post
Link to post
Hi i have test Photo interruptor sensor to detect sprocket hole and then trigger camera to take a picture and it works very good i think the RetroScan universal works the same way
but the camera need to have fast exposure 1/2000 or faster because the film move constantly
here is a movie clip when i test it i hand crank the film up to 18 fps no problem :)
https://www.youtube.com/watch?v=ABlW4jvSruM&frags=pl%2Cwn
Edited by Mattias Norberg
Share this post
Link to post
Looks good. That type of equipment is usually in the $5K to $10K range including the camera. Could you post a follow up video of the finished scanned video?
I'm wondering if anyone has tried taking a high fps (120 to 240 fps) video of a film clip projected on a screen in a dark room? It would be simple to grade the video of the film clip and slow the sequence down to real time in the editor. Instead of working with about 3,000 frames for a 3 minute reel they would have a few minutes of video with multiple segments of images for each frame that could recorded and slowed down to real time in a few minutes. If I still had my 8mm reels and projector I'd try this myself.
Share this post
Link to post
Hi my camera can do max 20 fps here you can see my main scanner setup it does about 7fps that i use https://www.flickr.com/photos/94271811@N03/11007177505/ and i use hall sensor to trigger the camera https://www.flickr.com/photos/94271811@N03/10312776126/
and here you can see some HDR captures i have done i run the film two times low and high exposure and join them with Avisynth
https://www.youtube.com/watch?v=o0tv4im6HPo&frags=pl%2Cwn
https://www.youtube.com/watch?v=nCcKXjlwgRw&frags=pl%2Cwn
https://www.youtube.com/watch?v=aQd5RWj3hrA
  • Like 1
Share this post
Link to post
Wow. Really well done. Great results. Great memories.
Share this post
Link to post
Who I am and what I do - I work in television as a broadcast television engineer and have history as a producer and editor in corporate and regional broadcast television.  I judge the unit based on my past experience in editing and Telecine transfer.  I have transferred many reels of film with this unit.  It does a surprisingly good job for the price of the unit.  Is it a Telecine level unit? No, but it does a good transfer as it scans every frame of film. It is many times better than trying to set up a projector and camera to do a transfer and dealing with the frame rate issues of 18 or 24 fps to 29.97 fps (US).  I did the speed calculation and adjusted the speed using some simple consumer grade software,  rendered it all then created DVDs of family home movies.  That is the point of this unit, transferring old 8mm and Super 8mm family movies so you don't lose your family memories.  I recommend the unit for that purpose.
Share this post
Link to post
Mattias I am legitimately stunned. That first link of Disney World on R8 is absolutely the most beautiful and sharp 8mm footage I have ever seen! Such incredible detail and colors that I dream of shooting today but obviously cannot. Fantastic work. I've seen 35mm scans look worse than this! haha.
I assume the cost and set up of your rig is quite expensive and complicated? I saw your flickr photo.
Share this post
Link to post
My results with the Wolverine were very similar to Daniel's example posted. It almost looks like it was captured at 360dpi and enlarged to 1080. Like I said, it makes otherwise sharp footage look like a Monet painting.
If you want to say it does a fine job for the money, I guess maybe that's the case since it's $300...but it would be completely unusable for me in any situation other than simply to know what was on the reel.
Share this post
Link to post
I guess it worth the $300 considering the +/- 20 scans it makes before it breaks.
20 divided by $300 = $15 a scan. It gives you a decent $15 scan...I guess.
And you may be luckier than me and get 40 or 50 scans out of it.
If you are going to look at the footage on your phone in the smallest of sizes, then maybe it is acceptable. I would not like to sign my name to the output of the Wolverine. It is painful to see.
I'm not a pixel pepper. I don't have to have 5K, but the image quality should not be painful to watch. You can't enjoy the movie. All you see is how bad it looks.
Share this post
Link to post
Doesn't the US have consumer protection? No way would you get away with a limited warranty like that in the UK. 20 uses? What a joke. Like a car you can use for three weeks.
Edited by Mark Dunn
Share this post
Link to post
Hahaaa "Consumer Protection" in the USA????
Have you seen who runs this place???
  • Like 1
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Media Blackout - Custom Cables and AKS
    FJS International
    Just Cinema Gear
    G-Force Grips
    Cinematography Books and Gear
