24V power connectors
Hi folks
Simple question. If I were to design a device that could at least optionally use 24V DC power, what sort of connector would we expect?
There are already several things in use for that, from various Fischer and Lemo connectors on specialist pieces of equipment, through XLRs of various pinouts. I know that Cine Power International use a rotating, speakon-style connector for their large batteries, which are specified to about 30V.
What's being used? What's out there? What's a good idea, and why?
Thanks for any thoughts,
Link to comment
It probably depends on which section of the market you're aiming for, but in my neck of the woods (rental houses, Alexa Mini, Amira, Red, DXL etc) the standard 24V battery connector is still a 3 pin XLR, even for 26V NiCad block batteries or 28V NiMH supplies like an Anton Bauer VCLX.
The other standard for 24V on-board accessories is a 3 pin Fischer 102 socket (sometimes known as an RS socket) as found on Arri cameras, DXL, breakout boxes etc.
Link to comment
Four hundred dollars for a cable.
I might go with the 3-pin XLR, it's a lighting application, even though I think the use of 3-pin XLR for non-audio applications is a bit dubious.
I did wonder if David was having a joke, that's got to be about 1¢ per electron. XLRs have been used for batteries for a very long time though. The low voltage directive starts at 75VDC, which surprised me. I'll test a 9V battery with my tongue but that's it.
Link to comment
