shubham tiwari Posted October 25, 2018 Share Posted October 25, 2018 I saw this frame in one of the tvc of coffee brand. And i wanted the same frame in one of the commercial i am working on for coffee house. In the frames beans are falling on the surface and fills the frame. As a amateur cinematographer i wanted to know Is it possible to shoot the shot fully on focus i.e Deep Focus. I pulled my camera aperture as low as possible. I am using lumix gh5 with 35-100mm lens. But result are still not satisfactory. I wanted to know how can i achieve deep focus in close up shot like this one. Link to comment Share on other sites More sharing options...
Phil Connolly Posted October 25, 2018 Share Posted October 25, 2018 You could use a tilt- shift lens - that would allow you to angle the plane of focus to match the varying distances of the coffee beans. Link to comment Share on other sites More sharing options...
Michael Rodin Posted October 25, 2018 Share Posted October 25, 2018 Look up Scheimpflug principle. Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted October 25, 2018 Premium Member Share Posted October 25, 2018 Use a tilt-focus lens and stop down as much as possible. Link to comment Share on other sites More sharing options...
Roberto Ditleff Posted October 26, 2018 Share Posted October 26, 2018 Hi, there is a new lens system called TS-160 Robusto, From infinity-photo optical, USA, http://www.infinity-usa.com. I helped the development of the lens and I can assure you, it does exactly what you are looking for, there is an adapter for any kind of lens mount from C to PL and the MTF is impressive. Roberto laguna Www.lagunafilms.com.br Link to comment Share on other sites More sharing options...
Premium Member Adrian Sierkowski Posted November 23, 2018 Premium Member Share Posted November 23, 2018 Fraizer lens/ Trex system lens comes to mind which would give focus basically from the front of the lens to infinity. If memory serves, the fraizer (from previously panavision) was something like a t 7.1 at it's most open. Link to comment Share on other sites More sharing options...
Adam Froehlich Posted November 24, 2018 Share Posted November 24, 2018 Hi, there is a new lens system called TS-160 Robusto, From infinity-photo optical, USA, http://www.infinity-usa.com. I helped the development of the lens and I can assure you, it does exactly what you are looking for, there is an adapter for any kind of lens mount from C to PL and the MTF is impressive. Roberto laguna Www.lagunafilms.com.br This lens seems interesting... @Roberto What would you say the effective aperture for this lens would be? I know macro and micro lenses behave a little different with light loss, so how much light would actually be needed to get proper exposure, with a decent DoF so close to the lens? I ask because I have some hi-speed projects with a Phantom Flex in the works, and exposure at 2000fps already requires so much light, I would be worried that the high speeds + small aperture would compound into a massive amount of light required, something we hope to avoid. Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted November 24, 2018 Premium Member Share Posted November 24, 2018 It’s unavoidable, you need a lot of light to get deep focus, especially in macro photography and even more so for high speed photography. On the plus side, macro photography often involves such a small area to light that you can bring a light closer to the subject for more exposure. Link to comment Share on other sites More sharing options...
