Hello,
I'm interested in hearing from people who've shot with the Venice. I have a shoot coming up and might use it. I've heard great things and saw Claudio Miranda's tests which looked great (maybe that has something to do with the DP though :) ).
I love the dual ISO and 1 stop ND increments. To utilize full frame I know you need the R7 recorder which makes it quite the load. Doesn't seem like this would work on gimbals.
But it sounds like its a completely new sensor which should be a good thing i'm guessing.
Thoughts?
Michael
Link to post
It's not clear in the literature if all 4K recording modes are a crop of the 6K sensor or if you can, for example, record 6K raw and a 4K XAVC downsample at the same time:
https://pro.sony/ue_US/products/digital-cinema-cameras/venice#ProductSpecificationsBlock-venice
https://pro.sony/en_IE/products/digital-cinema-cameras/venice
Link to post
AFAIK you can't Rec 6K raw and 4K XAVC at the same time.. one or the other.. need the license for any 6K ..OCN can be 6K .. with R7 recorder attached ..otherwise its FF 6K down sampled to 4K for XAVC internal .. without license 4k would be a crop of the 6K sensor.. as I know it and info from the FB 5/55 Venice page..
Link to post
Are you sure it is downsampled and not a crop to 4K? I kept searching online to clarify that. Sony charts and specs just show 4K as a sensor crop from 6K. I can't find any verification that when you record 4K, it is a downsample of the full-frame 6K sensor.
Link to post
From the Sony info you posted.. firmware update being V2 I presume . and you would need the 6K license ..
6K high resolution*
The stunning full 6K resolution of the camera can be recorded directly in X-OCN (16-bit eXtended tonal range Original Camera Negative) file format. Also, XAVC 4K can be captured onto SxS cards while still sampling from the full 6K resolution of the sensor.
*Firmware update required.
Link to post
I think that was part of the Venice thing.. the trend towards over sampled 4K.. or true 4K as some say after debayer.. I think personally they should have sold the camera as 6K out of the box without having to buy the license .. but I guess they want to keep the price down.. and it is very good value ..for people who only need 4K..
Link to post
It's great that it has a downsampled 4k option. With bayer sensors, that really does seem to be the key to "filling in the gaps" image quality wise.
I just wish they'd implement XAVC's full spec of 12-bit 4:4:4. 6K downsampled to a 'true' 12-bit 4:4:4 4k image (with the comfortable data load and easy editing that XAVC provides) would make for a terrific onboard mastering codec for all but the most demanding requirements.
Canon have the same stupid limitation with their C700. 5.7k downsampled to a 'true' 4k... but then they throw away half of the chroma information like Sony with 4:2:2 recording.
Link to post
Am I the only person who's a little impatient with the endless rebranding of various flavours of MPEG-4 under pointless, needlessly-incompatible corporate terminology?
XAVC, AVC-Intra and AVCHD, and their multitudinous sub-sub-subtypes, are all essentially MPEG-4 AVC; any compliant decoder will decode them, except the ones in the nonlinear edit suites tend to be not so compliant and designed to handle only one variant.
Grr.
I'm not sure what Sony's OCN baby is, but I wouldn't be surprised if it was yet another AVC rebranding. Anyone know?
Link to post
And to top it off, none of them offer the simple (superior) drag-and-drop nature of ye olde Prores.
Link to post
I agree. XAVC 12-bit should be available on this camera. As of now it only allows for 16-bit OCN or 10 bit XAVC 4K/ProRes HD. Nothing in between
Link to post
  • 2 months later...
I used it the other day in two really small commercials and I wanted to share my Venice experience
First of all, I have to say that it took me a while to get used to the extremely clean look of the image. After many years looking through the viewfinder of an Alexa looking at the image that the Venice offers to you is quite a shock! Specially in my case because I'm used to shooting with the Alexa at 3200ASA ha! so seeing a nice, clean image was like: WOW!
For starters the viewfinder is, probably, the best I've looked through in digital times (the EVF2 from the LF is not as good as the Venice one.. although it is quite an improvement from the EVF1)
The shock that I got was probably because of the lenses, I used a set of Cooke S2s because those were the only ones that the rental house had available at the time.
I don't really like the S2s or S4 lenses but they worked fine.
Homestore + More - Home (Dad)
Homestore + More - Home (Daughter)
I shot with it at 2500ASA and also at 500ASA.
I was extremely pleased at how the camera worked and the way it is designed, I had wanted to use it on the field for a while and it lived up to the expectations.
For what is worth, I think that I prefer the texture from the images at 2500ASA and it is probably a camera that I'd love to underexpose a lot (this one was not the right project to underexpose the image unfortunately!) because there is a LOT of information in the shadows, as in.. infinite information :D, more than what I'm used to having anyways.
I was going to use it during the next weekend for a short-film but unfortunately they don't have it available.
I'm going to go to Madrid soon and I think that I'm going to get the camera out for a day / night to see what it can really do, coupled with the right lenses, it has to give beautiful results.
Have a lovely day!
  • Upvote 1
Link to post
Kinda off topic but how did you have it rigged for those two videos you posted? Were you using an e-z rig for the handheld stuff? Or was your build light enough to do shoulder?
Link to post
Hi Ryan!
All of it was hand-held and I only used the easyrig in one shot (the one of the kid looking at the flowers) because the flower pot was in between the kid and myself and I couldn't hold the camera at that height without the easyrig!
Other than that, everything was either on my shoulder or just grabbing the camera by the handle (which I tend to do quite a lot nowadays).
The Venice is very compact and even though it is pretty solid, it is very well balanced while on the shoulder.
In fact, it is much better balanced than an Alexa Mini or any other Alexas.
Have a lovey day!
Link to post
Miguel .. glad you liked the Venice .. I think Sony has eventually got it right.. its taken them a while !!.. yes the VF is amazing .. you can also use them on the f5/55 ..(not fs7).. a lot better than the original Sony OLED VF.. now if only they were half the price.. !! I think it might be still on there web site.. but TopTeks in the UK did a comparison test of Alexa Mini F55. and Venice weight wise as a hand held camera..
Link to post
Thanks very much for the info! I think I'd like to try the venice on a shoot and see how I like it.
Link to post
  • 1 month later...
1
Hey Miguel so I assume you shot in 4K with the Venice and not the full frame 6K as the lenses wouldn't cover the sensor?
Link to post
46 minutes ago, Kevin Descheemaeker said:
Hi Kevin,
I shot at 4K, that's correct, no need for full frame, it would have been nice but our budget didn't allow for anything else than Super 35 lenses.
Have a lovely day.
Best.
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
