ARRI D21 and CODEX 3010 ARRIRAW problem! Help!
Andrius Zemaitis
I have a problem in connecting ARRI D21 and CODEX 3010 to record ARRIRAW format.
My situation: I set ARRI D21 camera internal settings to ARRIRAW format, output HD-SDI1 frame rate 24fps. Then I set CODEX internal parameters: format ARRIRAW 2880 / 24fps. I connect camera and recorder with DUAL sdi cable in proper order A with 1 and B with 2.
And then CODEX says "Input video signal wrong type: HD1080p@"
I was readed ARRI D21 manual and setup, and connect system as it was showed in manual. I dont know where is the problem?
What I do wrong?
Looking forward.
Please help me on this insulting case...
Link to comment
Thanks for comment. I was speak with CODEX guys and already solve the problem. Everything works fine. But I have other problem. I dont have DOCK station and cant transfare data from codex to PC.
Is it possible to somehow connect device via Ethernet cable?
Second question if I buy Dock transfare station for codex is it suitable to Windows user?
Link to comment
  • 4 years later...
