David Tilburey
Arri Skypanel frequency setting
Does anyone have any information on what the frequencies are in the menu.
Frequency 1 =
Frequency 2 =
Etc
Thanks in advance.
DT
Share this post
Link to post
As described in the manual:
Frequency Selection
This feature allows fine-tuning of the frequency of the SkyPanel’s light output to adjust for slight flicker or roll bars that might occur when shooting at uncommon frame rates or shutter angles. Pick from 10 different frequencies that could reduce or eliminate small amounts of these image anomalies, while maintaining full control over intensity and color tuneability.
Share this post
Link to post
Frequency Selection
I think he is asking what the rate is at 1 and at 2
there are 10 to choose from.
Share this post
Link to post
the manual doesnt list a frequency rate:
"You can change the frequency in the fixture menu. Change the frequency, when you recognize flicker when in the camera picture or by your eyes. The default frequency is the highest frequency. You can change the frequency in 10 steps. Frequency 1 is the highest frequency, while frequency 10 is the lowest frequency setting."
Share this post
Link to post
Thanks JD.
Ed You're absolutely right. And thanks for the response.
With just about every other fixture I can adjust the frequency specifically, 1k,2.5k etc but to match skypanels to the system is more of a trial and error situation.
I'm wondering if anyone has put a scope on an S60 to find more detail.
Thanks again..
DT
Share this post
Link to post
Why would you ever need to know since the adjustment is by eye?
Share this post
Link to post
Simplicity and knowledge. Fixture profiles. All good thought someone might know. cheers DT
Share this post
Link to post
Hi David,
You mention frequencies is the 1000Hz plus range, is the intent to use the Skypanels for high-speed photography? I'm sure you're already aware of it, but I would certainly recommend using the dedicated high-speed mode.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Media Blackout - Custom Cables and AKS
    The Original Slider
    Just Cinema Gear
    FJS International
    G-Force Grips
    Cinematography Books and Gear
