panagiotis agapitou
Is it really cheaper to shoot in digital ?
Film is cheaper. When exposing film you need a lab where someone develops your pictures. You come in contact with lab people which typically is priceless. If you want to buy yourself into such human relations in the digital world, you need a lot of money.
  • Like 1
Share this post
Link to post
11 hours ago, panagiotis agapitou said:
Thats not really a like-for-like comparison. The article is question is discussing the increase in domestic use of reel to reel players nothing to do with how music is generally produced. Its no different to the hardcore of super 8 and 16mm collectors that run movies for nostalgia reasons.  This is a response to the intangibility of mp3 and the desire to have physical copy.
Film production has its own demands
The reel to reel domestic revival is also very limited by the tapes being produced in the format. The proper analogue 15 inch per second recordings are v expensive to make: https://tapeproject.com/product/the-band-stage-fright/ . So even in this case digital is vastly cheaper and no domestic analogue tape is not going to sound better then a 24bit 96Khz uncompressed file with even a mid range DAC.
In terms of the use of analogue tape for music production, it never went away and there are plenty of studios that track on 2" prior to editing on Pro Tools. Blank analogue tape (even 2") is of course a lot cheaper then filmstock and can be reused and re-recorded - so the comparison is becoming tenuous.  Analogue tape is often used in music production a much for its technical flaws e.g harmonic distortion
Share this post
Link to post
Before getting into film I used to work in a boutique studio that did 2" analog recording. I loved the way it sounded, and sometimes we even ran 30 ips which chewed through the tape in double the time. But like you said you can re use it (i never personally would, but you can) and it's not tremendously expensive.
I thank god that I like the look of Alexa footage because the uphill battle of analog vs digital today is too tiring. Film and digi are both good looking, unlike the gap between digital vs 2" tape based music (all my opinion of course).
In hypothetical world, I would entertain shooting film if the budget was big enough, but even then it seems like why not shoot it on an Alexa with amazing glass and put that money elsewhere?
Share this post
Link to post
I mean, I can't afford a 4k Alexa... even the Alexa XT's which are only 3.8k, are still way out of my price range. I mean even a Red Dragon package is around $14 - $18k and you're dealing with something that WILL FAIL at one point during your ownership. Red's are notorious for software glitches and they charge a fortune to service them. So then you talk about Sony, but again the price range is astronomical for a true cinema look like an F65 or Venice with all the bells and whistles. Reality is, owning a true digital cinema camera that you can garnish gigs from, is unfortunately cost prohibitive, unless you're using the equipment every day and have enough connections to have consistent work.
So then you've got the other aspect which is, everyone shoots digital, so what separates your production from the guy's film that shows before or after yours at the film festival? Sure, you can treat digital to look more filmic, but it never will look like film. How much attention does your production get when you say "shot on Alexa" vs "shot on film". Most people will stop and read an article on why you're using archaic technology to make your movie, but an article about shooting like everyone else, what interest is that? When digital was first coming around, this was the opposite, everyone wanted to read about the digital shoots. However, now that the roles are reversed, film has become the stand-out choice for indy filmmakers to define their production.
The mandatory discipline that's built into shooting on film, is in essence the saving grace of the format. Thus, the results are generally better for less production time. You COULD be disciplined like that with digital, but when the shooting time is endless, EVERYONE becomes lazy. Plus, in today's world, when actors know you're shooting film, they step up to the challenge because they know it's special. Back to the results part of shooting on film, it does make a difference. Where it may be less apparent on bigger productions, on smaller one's, I've physically seen the difference first hand and it's pretty amazing if you actually did an A/B comparison.
Finally, digital is not just one's and zero's. It's an encoded media format which will fall out of date very fast. As technology moves forward, we find ourselves at a precipice where in 10 - 20 years, the files we have today will not be playable on modern hardware. So now you're having to keep old hardware around to playback your files, which again are stuck at whatever resolution you shot them on initially. Plus, can you afford to store 20tb for 20 years? No spinning disk or SSD will last that long, so there goes all those raw file drives. Now you're going to back them up onto LTO tape, which is great, but in 20 years the current LTO format will be long gone as biometric tech takes over. So again, how will you ever watch your final production without A LOT of money being put into properly archiving every few years to a new medium and transcoding to newer codec's? The studio's have rated the cost of doing this archiving at several thousand dollars per month, per show. Where camera negative is completely agnostic to these issues. It can sit on a shelf in your closet for 50 years without fading. It can sit in a cool vault for 100 years without any damage. If you want to re-edit, simply re-scan the scenes you need and re-conform your cut. Recording back to film today is cheaper than it's ever been, with costs as low as $100/minute for 2k. So now you can store a print along with your negative in a vault for what, few hundred bux a year.
I understand digital, I think it's great technology for television, streaming/web and making videos for fun. I don't understand digital for anything that has any long-term integral value.
  • Like 1
Share this post
Link to post
Tyler, while this is technically true, in most situations it doesn't apply.  If we originate on film, it gets scanned and finished through a digital pipeline.  And at that point, the project really only exists in the digital realm.
I shot my last film origination in 2008 and it went through a DI to a film out for theatrical release on film.
Cut to: 6 years later I get a call from Sony Pictures.  They have not been able to contact the producers, so they wanted to know if I would like the original camera negatives.  All 100,000 feet of it.  They kindly offered to deliver it to me, or it would be destroyed in the next month. I declined.  I hope that they have saved the master digital to film negatives, but who knows?  But without a master cut/conformed film negative, there is really nothing analogue to archive unless one desires to reproduce the entire post production process...
Share this post
Link to post
I have seen lots of local early 2000's movies which went through a DI and digital grading and in the recent years the producers/distributors wanted to do a new dcp or hd tv release out of them. that has been proved to be surprisingly difficult considering the early days of DI where they recorded the graded movie directly back to film for striking 35mm prints and then did the tv master on beta or digibeta tapes and that's it (no hdcam sr yet). the graded DPX intermediate was generally not saved (hdd space was expensive back then) and one can't really scan scratched and high contrast print copy to get a 2k quality version of the film for re release. Meaning that one basically does not have any decent quality color graded version of the movie at all in good enough quality and one needs to reconform and rescan and re grade the whole movie from the original camera negatives to be able to make a 2k digital version out of it. AND do the vfx again if there was any.
The whole process is extremely cost prohibitive (will cost at least tens of K's to do) and they may give up the idea when hearing how close to impossible it actually is to do for reasonable price.
another thing is those rare D6 tapes used for doing the hd masters in the early 2000's. One is extremely lucky to find a working machine to play back those (those are extremely rare, only couple of them in working condition in the whole world) and that is basically the only graded usable master one has apart from the film prints. the alternative is to again rescan and regrade everything.
the hdcam sr masters made it a little bit easier because there were actually an existing hd quality tape you could find a working deck for and could actually play it back and get the image out of it. That was very helpful after the erased dpx nightmare and the D6 times 🙂
anyway, nowadays it is best to stick to the most useful standard formats I think. Audio as separate .wav or .aiff 24/48 files, the picture in both prores 444 and dpx or tiff files. clean versions without bars and separate subtitle files if available. archive to LTO and do the other copies to the mediums of choice (ssd, hdd, raid, network storage, cloud, etc.) and migrate to new media types as needed.
  • Like 1
Share this post
Link to post
basically it gets easier and easier the more standardised and widely used the same technology is outside the very niche film industry. For example the introduction of HDCAM and HDCAM SR (designed for TV use) simplified the post workflows here a lot and enabled making reasonable priced hd masters of the movies for later use. The file based workflows have simplified it even more because basic computer gear can be adapted to work for movie post production use. and LTO for example is used for lots of other uses outside the film industry so there is always a working LTO deck somewhere which can be used if the company's own machine breaks. No more those super rare expensive tape formats with one working machine for each continent...
both the availability of the technology is much better but it is much cheaper as well. for example a basic LTO system as a whole is maybe one tenth of the price of what a HDCAM deck would have cost years ago
  • Like 1
Share this post
Link to post
Well sure, but if you do your own work, you'll most likely keep your camera negative. If you're a gun for hire doing work for other people, I guess it's up to them or the studio to figure out how things are stored. Many films are lasered back to film in either an IN process OR RGB separation negatives for long-term storage.
For the record, studio's generally only destroy camera negative that has no value to them. There are dozens of vaults in Los Angeles alone that store pretty much every major film ever shot. There is no reason why the studio would throw something away, unless it lost them money and they didn't care about the asset. The cost to shelf 100,000ft isn't that much, that's basically 100 boxes of film, not the end of the world.
Share this post
Link to post
I think film out records are a useful solution for long term archiving. But on films that are mastered as a digital file (most of them), they are an optical generation away and re-scanning in the future could result in shifts in colour and density compared to the digital original.
Its perhaps a cost effective solution compared to migrating the digital files from one medium to the next every 10 years or so. That process gets expensive. But technically its not the best possible version, it being an analogue generation from the digital master. It would be technically preferable to retain access to the uncompressed digital file in its original form (or a lossless copy). From an archive perspective thats better and allows for perfect digital copies to be distributed (the advantage of digital)
Of course we know the archiving of digital files is a really difficult problem and the current typically magnetic solutions are not good enough. I've worked with LTOs and 1", D5 - the future long term stability of those formats isn't great.
However, it is a problem that needs to be solved, the vast bulk of Human knowledge and information is sitting on magnetic media. Not just movies, but the entire internet. So more stable long term digital storage technologies will need to be created.
Right now we are in a transitional phase where current tech can't really deal with the mid to long term archiving of everything being created. I wouldn't not be surprised if  firms like Google and Amazon are throwing millions into R & D for the next generation of data storage.  Quantum computing technologies that seem sci-fi now, will at some point become practical.
Ideally we need to find a way to secure these digital film masters long term.
Holding onto the camera neg is useful for revisions of films,
But If I wanted to watch a film I'd rather have digital master if thats the format the film was produced in, then a new version created by reconfirming and scanning to OCN.
For instances:
Take 'O Brother Where Art Thou?" - one of the first 2K DI's. Thats the version of the film, I'd want to watch, the 2K version that had Deakins in the suite making the grading decisions. Digital scanning and grading has moved on since that film was produced. But the film is an achievement,  partially because it is using the then available tech.
Sure, you could go back to the camera neg, re-scan in 4K+, reconform etc... Technically you could create a "better" version  of "O Brother Where Are Thou?".  It would be sharper more detailed, more subtle grading, perhaps be HDR etc..
But it wouldn't be the version that represents the filmmakers original intent, or the version that audiences saw in cinemas.
It would be close to impossible to recreate a matching version of "O Brother Where Art Thou?" By going back to the OCN and rescanning. Not matter how careful the restoration team would be, its going to risk changes e.g the scanner may be different, the grading tools different, it could be close but its different.
I might event enjoy watching the new Dolby 4K HDR, ATMOS version of "O Brother", but not at the expense of loosing the original.
Now, I'm not against restoration, I'm glad Lawrence of Arabia was restored by Robert Harris, because it he hadn't done it the full version of the film would have been lost. Restoration should rightly happen when the original elements are damaged or faded and work is needed to try and match the film makers intent.
But its preferable not to loose the film in the first place.
Share this post
Link to post
Yes, "lasered" (not really a word :), back to film does not suggest that film origination is a factor in in the benefits of film as a long term storage solution.  Any digitally originated film can be ultimately stored on film for the long term through this process.  But film origination is not a necessary part of this work flow.
So, shoot digital if you'd like.  It ultimately won't make a difference in the long term archiving of the project.
Share this post
Link to post
"Arri Laser" is a film recorder, so what would a film that has used that scanner be called after the process is done? Wouldn't that be "lasered" as in past tense of "laser"?
Where it is true that anything can be recorded back to film and quite a few movies have for archive purposes alone, my point was that if you DO save the negative, you are insuring the film does withstand the test of time. Yes IN's or separation negatives aren't the same thing if they've been made from digital sources. However, it is the only long-term archiving solution we have today.
Share this post
Link to post
Is it cheaper, digital? Anyway, think of a pair of shoes. What's best, a cheaper pair, or a more expensive pair. Think about that a moment. It's deep.
Share this post
Link to post
I was just joking about the word "lasered".  It did make sense to me though!
  • Like 1
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Rig Wheels Passport
    FJS International
    G-Force Grips
    Just Cinema Gear
