Davide Sette
Arri 16 SrII - A problem in mounting lens
Hi, I'm Davide. A young film-maker from Italy. Great to be on this very useful forum.
I've recently bought an Arri 16 srII and an Optar Illumina Lens for it, but I can't mount the lens on the camera. The mount (b-mount) should be ok, but the lens doesn't fit properly and doesn't rotate.
Any suggestions?
Share this post
Link to post
2 hours ago, Tyler Purcell said:
Try holding down the unlock latches as you twist the lens.
Thank you for your answer. I've tried holding down the unlock latches but nothing happens. Do yo think it is the right mount for the camera?
Share this post
Link to post
Yes, everything looks great! Lenses are the right lenses, mount looks fine. I sadly haven't used Arri B mount cameras in nearly 20 years! But I do remember it only going in one way.
Share this post
Link to post
It should fit in smoothly, right? It seems to me that the only way to insert it is to press hard. So I assume there's something wrong.
Share this post
Link to post
Do other Bayonet mount lenses fit OK?
Try and check that the lens is not hitting any internal baffles or other things inside the camera mount. The camera doesn't look like it has the old auto-aperture mechanism, but check there is nothing like that preventing the lens from being fitted. (See old manuals like this: http://www.duallcamera.com/Arri 16SR.pdf where they describe fitting steel Bayonet lenses.)
As Jean-Louis mentioned, check for any signs of impact or deformation.
The lens should clear the mirror, but check that when it is pushed in as far as it will go you can still inch the camera (turning the mirror) without any resistance.
If nothing helps you may need to send it to a technician for a proper inspection.
Share this post
Link to post
It doesn’t go far than this (I’m able to inch the camera). A lens with Arri standard mount should work, right?
Edited by Davide Sette
Share this post
Link to post
This is because your Mount is missing the Metall- Ring which usually keeps the Iris/Focus Gear in place which older SR´s had.
As long as you can Focus to Infinity you won't have any problem.
See Picture below!
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Paralinx LLC
    FJS International
    G-Force Grips
    Just Cinema Gear
    The Original Slider
    Cinematography Books and Gear
