Im about to shoot a short film on 16mm, and were gonna use back projection (the projection itself would be digital, and its material shot on digital camera).  I would appreciate any advice since i never did this.
my concerns are mostly two:
1. whats the best way to expose/ measure the projection?
2. should I take any special precautions to avoid flickering? or will it be fine just as long as the camera and the projector are set to the same frame rate?
if i plan to use hand cranck, I imagine there is no way to avoid  variable flickering, right?
Daniel
Share this post
Link to post
I wold spot meter the projection maybe put up a chart with a greyscale and a white point to get an idea of exposure with the spot meter.
Really depends on the projector, I think 3-chip DLP or LCoS or LCD are what you want to try, avoid a single chip DLP with a color wheel.
Share this post
Link to post
Thanks Robert,
You mean shoot a gray chart, and then project and measure the gray chart off the projection, right?
Share this post
Link to post
I would just get a commonly available reference chart which has white/black and grey patches (Maybe look at Light Illusion web site) and project that.
Then use the spot meter to determine exposure range for the projector.
I would recommend a daylight balanced film stock as the projectors mostly try to hit a 6500deg white point more or less
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Just Cinema Gear
    FJS International
    The Original Slider
    G-Force Grips
    Cinematography Books and Gear
