Sushanta Barman
FLICKERING practical bulbs
Why is dslr cameras if we shoot a scene with a practical tungsten or LED bulb it causes flickering in the video footage?? I know a bit that the frequency of light doesn't match the frequency of camera but if I take my shutter speed from 1/120 to 1/30 there if no flickering seen in the video footage. Why?   What will happen if I use cine cameras ( it has shutter angle ) ?
Share this post
Link to post
Roughly speaking you want to make your shutter angle a multiple of the countries frequency... eg.. 1/50th /1/100th in 50Hz / 1/60th/120th.. in 60Hz countries .. for "normal" motion blur in cine mode there is a 180 degree "rule".. shutter is twice frame rate.. but if your shooting say 23.98p in a 50Hz location use 1/50th.. even if you have a 1/48th option.. to avoid flicker from practical lights ..  LED is also tricky as if they are in anyway dimmed then will flicker what ever you do.. !
  • Like 1
Share this post
Link to post
Yes, what you are saying is right, but I am still confused technically about  why lowering the shutter speed to 1/30 from 1/60 cause a flicker-free video footage ??
Edited by Sushanta Barman
Share this post
Link to post
yes no idea.. curse of LED lighting... but tungsten should not flicker .. unless shooting very high speed frame rate..
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • G-Force Grips
    FJS International
    Just Cinema Gear
