I've recently acquired a Cartoni Beta fluid head from a production company and it has many miles on it. I noticed the tilt action (fluid and spring) has "play" or an "air gap". As I tilt, say up, then turn to go back down, there is a small gap in the transision. It's slight but noticable enough to make a shot jerk during an innapropriate time. Pan is fine.
I've never encountered a fluid head with this before. Is this inherent of the Cartoni Beta? And most importantly, how do I get this fixed?
Regards,
Stephen Sanchez
Commercial Cinematographer in Tampa FL
Edited by Stephen Sanchez
Typo
Share this post
Link to post
I haven't worked on Cartoni heads, but in other heads play like that is often due to wear which requires replacement parts. Given that these heads are long discontinued, a repairer may find it hard to source parts. You could try asking somewhere like Visual Products, but I suspect it might be easier to just invest in another head. I don't think these are very expensive heads are they? I don't know if a newer Cartoni head will fit to the same tripod, or if you need to replace the whole thing.
It's worth checking that the play isn't simply a loose fitting somewhere, such as where the head mounts to the tripod. Sometimes a loose rosette where the pan handle attaches can feel like play in the head itself.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Paralinx LLC
    FJS International
    Just Cinema Gear
    G-Force Grips
    The Original Slider
    Cinematography Books and Gear
